Help troubleshoot my turbo problems! Help!
Old Feb 23, 2005
HyaBoosta's Avatar
well a few things are going on after I drove the car down the block. Vac is reading 18. Is that normal(in fla). My bov seems so wine a bit after I get off the gas. does that mean i need to tighten it?(greddy type S, vac line in the top port) and i've gone up to 5k rpms and still the gauge won;t reach boost but I feel the car pulling. I have a Turbo XS duel stage BC and the ***** on both are completely closed. if I had the vac imput and output lines backwards, would this cause the problem? thanks for you quick responses in advan
Old Feb 23, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Does the boost gauge read anything? Where is the line for the gauge tapped off of? Full throttle runs?
Old Feb 23, 2005
HyaBoosta's Avatar
reads 18 vac and goes to 0 but not to boost. I have a GE vac manifold that is t'ed off the brake booster and the boost gauges is on the manifold
Old Feb 24, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
my read 18 and sometime 20vac. i think that is normal.
Old Feb 24, 2005
HyaBoosta's Avatar
would having the vac. lines backwards on my Manuel BC cause this problem?
Old Feb 24, 2005
Possibly, hook up your boost gauge to the turbo. See what you are making. You may have a boost leak.
Old Feb 24, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
you meaning vac when at idle? I run about 21 vac at idle and average anything between 7-11 vac when cruising.
Old Feb 24, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
sounds like mine
CarStuff
Dec 6, 2020 12:52 PM
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
redej2
Apr 29, 2015 01:47 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
