intake air temp sensor.
Old Feb 23, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Hey what's up guys. I have a question for you all. I'm going to install my turbo within a few weeks and I just wanted to know what you turbo guys do with the intake air temp sensor. Do I keep it on the pipe that goes to the throttle body or do I put it on the intake pipe that connects to the turbo. Thanks for your help.
Old Feb 23, 2005
HyaBoosta's Avatar
well it can go either way. Mine is before the turbo but I want to change that. It is more accurate to have it just before the TB because that is the most accurate reading of the ait temp that is entering the engine.
Old Feb 23, 2005
C2i0v0i1C's Avatar
SuperMODrizd
there is a larger chance of throwing a code if its by the TB
Old Feb 23, 2005
HyaBoosta's Avatar
yeah thats true too^. Mine hasn't thrown a code.
Old Feb 23, 2005
civic01vtec's Avatar
mine is just tied off........still have no time to drill the charge pipe and install it
Old Feb 23, 2005
HyaBoosta's Avatar
so that means that it's reading cold as hell. how do you tune your fuel? you must be pig rich
Old Feb 23, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The IAT sensor NEEDS to be as close to the actual intake manifold as possible. This is because that is the temperature of the air that the engine sees. Before the turbo is significantly cooler than post turbo, and this will affect how the engine runs.
Old Feb 23, 2005
So putting it close to the throttle body is a good idea.
Old Feb 23, 2005
Yes.
Old Feb 25, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I am having a piece made by my machinist. Its a fitting that the stock senor drops into, it has an o-ring seal and a screw on cap that holds it from blowing out. The fitting welds into the intake piping just before the TB or in my case TBs lol. I will post pics of it as soon as I get it back to give you guys some ideas in case you are interested.
Old Feb 25, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
TBs?! Are you running ITBs? If so you've gotta post pics.
Old Feb 25, 2005
No, its the stock single throttle body.
Old Feb 25, 2005
Drk01Civic's Avatar
Not you, meathead. 02fpcivic
Old Feb 26, 2005
02fpcivic's Avatar
i dont have them finnished yet. im using some from a 954
Old Feb 26, 2005
02fpcivic's Avatar
still working with the fitment for the plenum and the vaccuum manifold assembly. Ill post pics on my site when its done. www.JDMFabtech.com. They should be sweet for my setup. IDK about as a single bolt on though, probably would be horrible for the stock rev range.
Old Feb 26, 2005
bimmerjim®'s Avatar
bimmerjim® is an unknown quantity at this point
we installed the air temp sensor in the botton side of the a rubber coupler on the upper charge pipe where the bov is located. its difficult to desctibe, but the pice provided with the TSI kit that holds the BOV had a sort of rubber port on the bottom side of it, we used a dremil to cut a jut right sized hole in it, and inserted the IAT sensor there. anywhere after the turbo is a good idea. technicaly, IN the intake manifold is the ideal place. but realilisticaly the intake air tempature change is nominal anywhere after the intercooler.
anyways., we put it in that same rubber coupler probibly 20 inches from the throttle body. the air temp sensor wires were extended.
Old Feb 28, 2005
Titleist71's Avatar
get of the ghey **** sites and you'll have time.....
lilrob1213
37
Jun 29, 2015 06:45 PM
steelfan95
Jun 19, 2015 07:15 PM
Allecr3
May 22, 2015 01:24 PM
carid
Apr 30, 2015 07:00 AM
se7en
Nov 12, 2001 10:13 AM
