turbo wrap up
Old Feb 19, 2005
fi dx's Avatar
fi dx is an unknown quantity at this point
turbo wrap up
on monday i started my turbo install...and this weekend i'm wrapping it up...just a few questions...when i'm routing the hoses for the boost controller it says i need a positive boost source to route one of the hoses for...where did everyone get their's from?...i see that there are some on the intake manifold..but does it matter that it is after the throttle body? and also anybody that has wired up the ignition harness for the e-manage?...what wires go where?...i looked on the greddy website but i was hoping for more clear instructions
Old Feb 19, 2005
fi dx's Avatar
nobody?
Old Feb 19, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
What kind of boost controller?
Old Feb 19, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Here's a pic of the pressure source many people use.
http://www.7thgencivic.com/forums/at...achmentid=3556
The Emanage Ignition wiring I think goes like this:
ECU Connector A (31 pins)
PIN 27 Brown (Ignition Coil 4) 'Cut' ECU side goes to Emanage Purple/White Wire Coil side goes to Emanage Purple/Black Wire
PIN 28 White/Blue (Ignition Coil 3) 'Cut' ECU side to Yellow/White; Coil side to Yellow/Black
PIN 29 Blue/Red (Coil 2) 'Cut' ECU side to Orange/White; Coil side to Orange/Black
PIN 30 Yellow/Green (Coil 1) Cut' ECU side to Blue/White; Coil side to Blue/Black
Light Blue and Pink wires are unused.
The only reason I say "I think" this is how it's wired is the fact that I haven't installed mine yet. From my understanding of the manual and a pin diagram I got from this site, I believe this is right. I'll hopefully be able to install this harness today if time allows. Please someone correct me if I'm wrong. Hope this helps.
Old Feb 20, 2005
fi dx's Avatar
i figured out the vaccuum lines and the ignition harness myself after some thinking and guessing...as for the wiring...it is not 4 3 2 1...i don't remember the exact order..but it is in the firing order by channels on the ignition harness....i think it was like 1 3 4 2
Old Feb 20, 2005
dezod's Avatar
7thgen Power Maker
http://www.7thgencivic.com/forums/sh...=186443&page=1
Originally Posted by dezod
E-Manage Links for people that need to set theirs up:
EMANAGE: WORKING SETUP FOR EXs!!!
http://www.7thgencivic.com/forums/sh...=164441&page=1
Base E-Manage Maps for Turbo'd D17 with working VTEC setup
http://www.7thgencivic.com/forums/sh...d.php?t=196730
Wiring schematics for our car:
http://www.7thgencivic.com/forums/sh...d.php?t=155306
VAFC wiring works the same as the E-Manage main harness, minus VTEC:
http://www.7thgencivic.com/forums/sh...d.php?t=169767
E-manage FAQ & Install Tips
http://mohdparts.com/emanage/EmanageFAQ.txt
Outlook of wiring for all 3 harnesses
http://mohdparts.com/emanage/manuals...-manage_10.JPG
http://mohdparts.com/emanage/install...elp/index.html
THE MYSTERY GRAY WIRE IS TPS, and is pin 15 of terminal A on our harness*
Some wiring tips for the ignition harness:
*pay particular attention to what wires go where (in terms of the INPUT and OUTPUT channels for the emanage) - you don't want to wire the OUTPUT of the emanage to the INPUT of the ECU - you may damage something
*the ignition harness has 8 wires you need to connect - 2 per channel (1 in 1 out), the injector harness has 4 wires you need to connect - 1 per channel.
*On connector A (31 pins) - which should be the very bottom connector on the ECU, pins 27, 28, 29, and 30 are for the ignition coils
*27 = cylinder 4, 28 = cylinder 3, 29 = cylinder 2, 30 = cylinder 1
*so.....channel 1 of emanage goes to cylinder 1, channel 2 to cylinder 3, channel 3 to cylinder 4, channel 4 to cylinder 2
*wire colors of the pins...pin 27 is brown, pin 28 is white/blue, pin 29 is blue/red, pin 30 is yellow/green. For the injectors you only use 4 of the 6 channels. The others you don't wire up.
Some wiring tips for the injector harness:
*wiring info for injectors is as follows: ch1 to pin 5, ch2 to pin 4, ch3 to pin 3 ch4 to pin 2
*Page 23 shows injector haress. Look at the diagram on the left - P/R = ch 4, Y/R = ch 3, O/R = ch 2, etc
http://www.mohdparts.com/emanage/man...-manage_23.JPG
*ignore channel A, B, 5, and 6.
Firmware you'll need:
http://mohdparts.com/emanage/pc/soft...1.13_info.html
The Support Tool update you'll need:
http://mohdparts.com/emanage/pc/firm....39/index.html
This will help a lot. Hence why we put it up.....
Old Feb 20, 2005
Drk01Civic's Avatar
That FAQ needs streamlining. Too much Bullshit to sift through.
Old Feb 20, 2005
Drk01Civic's Avatar
What about the ground wire on the injector harness (Blk/Red)? Can you just wire that to Connector A pin 4 or 5 (ECU ground) or is there a special injector grounding point used as a reference?
Old Feb 20, 2005
dezod's Avatar
7thgen Power Maker
Just the essentials there.....All depends upon what subject your looking for.
Old Feb 20, 2005
dezod's Avatar
7thgen Power Maker
I used the same grounding point for the harnesses.
UltraHDGames
Jun 8, 2016 05:16 PM
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
justcruzin125
Aug 11, 2015 09:09 PM
