boost problem?
Old Feb 1, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
boost problem?
My wastegate is rated at .4bar (6psi). Ever since i've had the turbo kit, i've always only boosted 6lbs and occasionally peaked at 7 for only a sec. Well, now, i peak at 7, and sustain 7psi!! Whats up with that? Is the wastegate actuator going bad? I'll get some pics of the gauges tomorrow. I know the gauges aren't wrong, becuase i not only have a mechanical boost gauge, but an electrical boost guage as well (on TSI's ICU) and they both read 7psi, well the mechanical one looks more like 8, but i know that has to be off.
Old Feb 2, 2005
18inchpride's Avatar
18inchpride is an unknown quantity at this point
would it be your spring? actuator sounds like the problem! how hard is that to replace! try adjusting for lower boost and see what your reading is
Old Feb 2, 2005
civicskater's Avatar
Chicks dig my scent
its gotta be your wastegate, thats all i can think of, definately play around with the spring and see what you get
Old Feb 2, 2005
TheSmuggler's Avatar
Uggg, sounds like creep finally got the best of you
Old Feb 2, 2005
HyaBoosta's Avatar
yeah the wg seems bad. is it a used turbo or new? External wategate owns joo
Old Feb 2, 2005
Boosting Daily
its used, 10k miles on it when bought. Well, an extra psi isn't so bad, but if it gets worse i'll replace it. There isn't anywere on it that i can play with the spring.
External does own me
Old Feb 2, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
bought it used, that probably contributed alot to it....just buy another wastegate...tial
Old Feb 2, 2005
^^Is your internal or external blue?
Old Feb 2, 2005
HyaBoosta's Avatar
yeah wear and tear. I've never adjusted an internal WG but i think it can be by adjust the actuator arm. Try a search for it
Old Feb 2, 2005
If the arms messed you can get a new one
Old Feb 2, 2005
Boosting Daily
True, but the kit was in superior shape for a killer price!!! $1900 w/ the manifold already shaved and fitted vs $3000 for a new kit.
Old Feb 2, 2005
Boosting Daily
cheap generic internal
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
