attn: K20 swapers
Old Jan 24, 2005
  #31
C2i0v0i1C's Avatar
SuperMODrizd
well i havent read the thread fully, but not jig rig anything ull pay in the end. ive got a sleeve k20 block ready to go in few weeks here but none the less dont take the cheapo steps to a swap
Old Jan 25, 2005
  #32
HondaLuver's Avatar
Its a celebration bitches!
never cut corners... you will pay in the long run, no matter what it is... you will sometimes learn from experience, ex. cheap tires, cheap ghetto rigged things... just get a k20 subframe...
Old Jan 26, 2005
  #33
1SiK CIviC's Avatar
1SiK CIviC is an unknown quantity at this point
i got mine through a company in canada.. i got a whole type R swap with suspension, brakes, axles, motor, tranny, ecu, harness, reseviors.. all for 5 grand
Old Jan 26, 2005
  #34
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
hrrrmmmmm so how much do k20 subframes go for anyways??
Old Jan 26, 2005
  #35
DFCivic's Avatar
DFCivic is an unknown quantity at this point
Originally Posted by hondasux
so what kind of modification do i have to do if i want to use the 7th gen subframe
If you dont know what needs to be done then i suggest you to not even bother!!
Spend the couple of hundred or whatever it is to get an rsx or si subframe.
Old Jan 26, 2005
  #36
DFCivic's Avatar
Originally Posted by HondaLuver
you can't use the tsx tranny... it doesn't fit, you will have to use a si or rsx tranny...
I am under the impression that all k-series trannies bolt up to all k-series blocks.
Unless you are positive that it wont work, im pretty sure they will work.
Old Jan 26, 2005
  #37
HondaLuver's Avatar
i am positive, it will bolt up, but, it wont fit correctly... why dont' you look around on clubrsx.com "hotwheelz" didn't use a tsx tranny cause it didn't fit when he put a tsx engine in his rsx.
Old Jan 26, 2005
  #38
DFCivic's Avatar
oh i see, some mount brackets probably have to be made.
justcruzin125
Aug 11, 2015 09:09 PM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
kenji4861
Dec 29, 2002 01:55 PM
Freshguju
98
Nov 11, 2002 10:09 AM
