attn: K20 swapers
I got mine for 3 grand. Motor, Tranny, ECU, Hasport Motor Mounts, Modified Wire Harness, SI Axels (4 Lug), Neu SPeed Short Shifter Adaptor, AEM CAI, 7,000 Miles on the motor.
I am gettin ready to do the swap and the cost of the engine, tranny, etc. will be $5500 plus shipping. I am getting it from Honda-Acura Parts in Sacramento. Still waiting to find out install costs. Plus the costs of upgrading the clutch/flywheel.
I got my k20a2 setup for 3K shipped including everything i needed and exhaust. Oh and i have an auto so i got the pedal and shifter too. Ebay. Mine will go in spring break. Im tryingto figure outthe wiring now before i take apart my car
Originally Posted by d17lpower03
is it safe to get them off ebay????
Originally Posted by 03CivicEX03
Do you really need rsx or si subframe for the swap, it is hard to find one?
Just get one from a local junk yard to avoid the high shipping costs. Straight up just get a phone book and start calling junk yards around your area.
BTW: have you purchased the hasport conversion harness yet? If so PM me please.
car-parts.com will solve ur problems.....you'll find anything u need.
ive done a lil research on doing a frankenstein swap hehe (k24a2 block, k20a2 head, 6spd tranny
) Last edited by scatman; Jan 24, 2005 at 09:09 PM.
7thgens official a$$hole
whats up with this stuff having shops do the swap, if your gonna sup up a car do it yourself, if not don't claim that "i did it" or going to be doing it" say that the shop did it or is doing it. your not really doing it just paying for it.
Don't Listen To What Anyone Says, It's Ok To Be Jealous
^^^ well thats why i wanna know if i need to buy a subframe or not... i will be putting in everything myself so i want to make sure i will have everything i need before i drop my d17 out....
right now i have a k20a
tranny ecu harness hasport harness hasport mounts
what else do i need to buy???
please pm me asap im planning to put this bi0tch in this weekend
"mmmBAHHHH" - vtec y0
some magazine that had a auto 7thgen and swapped in a k20 used the rsx subframe...when im home ill look up the name i think it was import racer or something like that i cant remember......i got so excited when i saw it its a shame they only gave it like 3 pages of coverage
you don't really need an rsx subframe you can always make your own rig up, but its just easier and probably cheaper than makeing one. atleast in this swap. in our crx h22 swap we made all of our own stuff(mounts,frame,axels)
Originally Posted by Scatman
ive done a lil research on doing a frankenstein swap hehe (k24 block, a2 head,6spd tranny
)Other benefits, the TSX dropout is cheaper, and you dont have to remove the head or any of that ****.
The one thing youll need is an rsx throttle body.
Hope that helps.
I learned the hard way. I bought my k20a2 and then wanted to do the k24 bottom end. Then i realized i should have just went with the tsx.
Originally Posted by DFCivic
Let me save you tons of labor and research. Get the tsx motor. It is basically the rsx A2 head and the k24 block WITH higher compression pistons. And you dont have to worry about overrevving or swapping pistons to avoid the infamouse valve-hitting-pistons theory. They say the crv block is safe but still not 100%
Hope that helps.
Hope that helps.
ok, i fixed my post.....i meant k24a2 (tsx) block, k20a2 (rsx-s) head, and the rsx-s 6 spd tranny.
K20A2 – US spec RSX type S motor
• 200 HP@7400 rpm
• Torque 142 lb/ft @ 6000 rpm
• Redline 8100 RPMS
K24A2 – US spec TSX motor
• 200 HP@6800 rpm
• Torque 166 lb/ft @ 4500 rpm
• Redline 7100 RPMS
my swap (if i decide to do it in the future) will torque quicker and still have a mean redline to wind up to. thats why im thinking this route over the entire k24
