intake air temp sensor!!
Old Jan 10, 2005
orso's Avatar
orso is an unknown quantity at this point
Question intake air temp sensor!!
ok i know this is probably a noob question but believe me when i say that i have searched and looked at the turbo install diy and what not, but i can not seem to find what you do with this sensor. i believe with the sf kit that it goes in the intake bonnet, but what about custom jobs? this is basically the only thing i have not figured out yet.
thanks in advance.
Old Jan 11, 2005
HyaBoosta's Avatar
you have to have a bung for it either right before the throttle body or on the intake pipe of the IC before the turbo.Those locations have been argued to which is better. right before the throttle is more accurate in the sence that it shows the temp of the air going into the TB and the filter location because it shows the temp of the air entering the whole system.
Old Jan 11, 2005
WannaBFast's Avatar
Prowlin' with a Purpose
now heres another question for you.. how is it supposed to be held in? if there is too much pressure that thing will blow outof the bung... am i right?
Old Jan 11, 2005
tfnaaf's Avatar
BLDNPSI Mod
Another member here has litteraly threaded the sensor with a die and you can weld a nut into the piping. I would show caution doing this as to not use to small of a die!
Old Jan 11, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i moved mine to the intake tube before the turbo
Old Jan 11, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
we tapped the charge pipe coming up from the intercooler to the throttle and squeezed a tight azz rubber bung in there to hold the sensor in place. So far, holds up nicely
Old Jan 11, 2005
civic01vtec's Avatar
i've seen mustang owners hold theirs in with rubber grommets.
I am gonna do what MadWheel did.......thread the sensor and drill and tap the charge pipe and screw it in.
Old Jan 11, 2005
orso's Avatar
hey thanks guys for your responses helped out alot.
Old Jan 12, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I'm planning on doing what Madwheel did too.
Old Jan 12, 2005
gotti's Avatar
I just drilled a ridiculously small hole in the charge pipe entering the throttle body and shoved a rubber grommet in it. The thing has yet to give me a problem
Old Jan 12, 2005
orso's Avatar
cool thanks
Allecr3
May 22, 2015 01:24 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
Blaster30
Apr 22, 2015 12:21 PM
se7en
Nov 12, 2001 10:13 AM
