*Boosted rev ?*
Boosting Daily
*Boosted rev ?*
I thought about something while i was at work today. Any boosted car you can think of, you imagine yourself at a light or whatnot reving and then pshhhhh. Well, my car dosen't build boost (T25) just reving, so i don't get a pshhh, more of a high pitched whooosh. Been thinking about it alot, then thought: Could it be because my d17a2 has high compression pistons? If so, when i upgrade to forged lower compression pistons, i should be able to build boost reving?
if i rev my car all the red to redline i get a peeeeeeewwwwww, and i have a t3/4
you gotta think tho we only have 1.7leters, and im only putting out 6lbs
when you rev there is no LOAD PRESSURE beeing made, thats why the bov sound isnt that great, im not sure if the turbo size has anything to do with it
just my .0000000003
just my .0000000003
now if you wanna let the bov off and do it F&F style, push the brake down, barely let your foot off the clutch, rev and release = bov.
Boosting Daily
Originally Posted by Michalo187
Arent high compression pistons really bad for the turbo set-up? I think with the low compression pistons you will be able to add more boost
Turbos, Engines, Chassis and Suspension Tech
Originally Posted by EternalBlue_Vic
Lower compression pistons are more efficient under higher boost(10psi+) than high compression pistons.
Not entirely true. They are less prone to detonation than higher compression when under high boost.
A 10:1 w/ 10psi, properly tuned, will make more power than an 8:1 w/ 10psi, properly tuned. However, you have a margin of safety with the 8:1 that you don't have with the 10:1, however great that may be.
/\/\automatic?
bwahahahhahahahahaa.........i wouldn't waste my time with a auto
although..........i am wasting my time with a sohc
Haha. Even though some of the fastest drag cars in the world are autos?
lol.......well, i don't have a drag car
Boosting Daily
Originally Posted by TheSmuggler
LOL, well I love wasting my time so I'm gonna waste it lolo
SolidHollow
15
Sep 13, 2015 11:18 AM
Bikergofast
Sep 12, 2015 10:54 AM
Bricoleur
Sep 9, 2015 12:30 PM
