Emanage Communication Problem
Old Jan 3, 2005
HyaBoosta's Avatar
Ok so I have gone thru 3 different USB to serial adapters and none have worked. Im not sure if it's me or what. I have only hooked up the power and ground to the emanage.Shouldn't it be saying that the system is online when I connect to my laptop and open the emenage support tool. All it says is Communication is off line do I want tot continue.
I've tried a Radio shack connector,Belkins, Ioe Gear and none so far. Could I need to connect more of the wiring so that there is data to transmit?
Old Jan 3, 2005
abmerop18's Avatar
Jam out with your clam out.
are you using the usb to serial cable from the support tool or just one you picked up at a store? it will only work witht he one from the support tool because greddy made it so that the cable scrambles the information and it can only be read with their cable.
if that is not the problem, you may want to upgrading to the latest firmware for the e-manage
Old Jan 3, 2005
HyaBoosta's Avatar
does your laptop have a serial port? because mine doesn't. I am using the greddy wire but at the end I need to put a usb adaptor so it can plug into my laptop.
Old Jan 3, 2005
TheSmuggler's Avatar
^^Oh man this is gonna suck, because my laptop dosent have a serial port either... only 6 usb ports..
Old Jan 3, 2005
opto_isolator's Avatar
The belkin one Best Buy sells works fine...That's what I'm using.
Old Jan 3, 2005
Havok2k1's Avatar
Wicked Pissah Admin
If you truly believe that it "scrambles the information," I have some land in florida to sell you....
Old Jan 3, 2005
Hey hey, land in flroida aint cheap no mo lol =)
Old Jan 3, 2005
abmerop18's Avatar
http://forums.evolutionm.net/archive...p/t-53809.html
Old Jan 3, 2005
HyaBoosta's Avatar
well I found the prob. someone on honda-tech helped. all I had to do was change the com port on the support tool software to 3 and it worked fine.
Old Jan 3, 2005
abmerop18's Avatar
nice happy tuning y0
Old Jan 4, 2005
HyaBoosta's Avatar
I ran into a prob. when I was wiring up the rest. Correct me if I'm wrong but Con. A is the top plug right? Because I don;t have a red/w blk striped wire coming out. I have Red/yellow, Red/Blue, and Red/White but no red/black. any help?
Old Jan 6, 2005
abmerop18's Avatar
is the 9 pin adapter on the support tool a male or female connection? i am just wondering because my laptop has a male 9 pin adapter port that would connect to the support tool if the 9 pin on there was female. i need to know so i can decide if i need a serial to usb adapter or not.
Old Jan 6, 2005
HyaBoosta's Avatar
i'll take a look after work and check
Old Jan 6, 2005
Havok2k1's Avatar
Wicked Pissah Admin
you believe everthing you read on the internet?
Old Jan 6, 2005
Yes... the internet tells no lies lol
Old Jan 6, 2005
abmerop18's Avatar
ask anyone on here and they will tell you that any generic cable you get from office max or whatnot will not work as a substitute to the greddy cable
Old Jan 7, 2005
HyaBoosta's Avatar
^^ true story. Im not sure about the scambling part but i know you have to use the greddy cable or find someone that makes a realllly good clone cable.
Old Jan 7, 2005
abmerop18's Avatar
did you find out about the connection on the seria side of the greddy cable?
Old Jan 7, 2005
HyaBoosta's Avatar
greddy cable is a female
Old Jan 7, 2005
abmerop18's Avatar
ok cool. thats what i need. thanks.
Old Jan 7, 2005
whats that mean, serial end plugs into the greddy unit and usb plugs into my laptop? I'm lost lol
Old Jan 8, 2005
HyaBoosta's Avatar
well Thanks to the great help and support from Trini at TRS in fla. I got it up and running. these guys are great with emanage and are makeing 460 hp on it.
Old Jan 8, 2005
Welp didnt get my ? answered lol
Lopes101
Jun 7, 2015 08:04 PM
blaketippett
May 29, 2015 08:02 AM
dooner24
Apr 14, 2015 07:51 PM
01IncaPearl
Jan 23, 2002 09:49 AM
