Pics of Oil feed T??
Hey Im getting ready to install my tubro within the next few weeks. Im doing all the prep work now so I can have everything ready to bolt on so I don;t have too much down time without a car. Can anyone hook me up with a shot of the way they set up the T from the block to the turbo feed. and the connection to the oil pressure sensor?
Turbos, Engines, Chassis and Suspension Tech
What size are you talking about?
The thread pitch on the oil sender is 1/8 BSPT.
The block is also the same.
The sensor is about an inch across, and has one wire connected to it.
the sensor threads right onto the T. Take the old one to NAPA and get a new brass T. I did. $.50.and its good n clean. It really is alot easier than your making it out to be. Use a thread gauge if u dont know what the size or gauge of the threads are. I don't know what yours is, but my lines may be a diff. size. Not sure if its 1/8 or not. Could be going in the block and thats it. Measure it or take it to napa. They will tell you what it is.
haha, i hated installing my oil feed line........it sucked holding a flashlight and 2 wrenches while working in a tight space...........but u'll git-r-done
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
