Ever hear of Überdata?
Old Dec 7, 2004
abmerop18's Avatar
Jam out with your clam out.
supposidly it is a free engine management program that is way better than hondata. i have been reading alot about it on honda tech and other fourms and it sounds great. it is a free program you download and install onto your ECU through a port you solder on. it does all sorts of data logging and engine management functions and best of all is free.
Überdata Homepage
Honda-Tech Threads about Überdata:
http://honda-tech.com/zerothread?id=1057012
http://honda-tech.com/zerothread?id=1070955
http://honda-tech.com/zerothread?id=984156
Old Dec 7, 2004
abmerop18's Avatar
bah. only works for obd1 ECU's but still a nice mod if you can somehow make it work or have an older civic/teg.
Old Dec 7, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yes I have heard of it. I have fairly extensive expirence with it, as well as Hondata.
Old Dec 8, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
It basically is Hondata, but without all the cost. I know they've built in some additional features, but it tunes and acts mostly like Hondata.
I just wish it worked on our ecu's... free is so nice.
Old Dec 8, 2004
dezod's Avatar
7thgen Power Maker
Uberdata is nice.
OBD1 pwnz ODB2 in every case.
Old Dec 8, 2004
Originally Posted by dezod
Uberdata is nice.
Not every.
Old Dec 8, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by 4drcivic2k1
Not every.
True, but IMO about 90% of the time OBD1 > OBD2.
Old Dec 8, 2004
abmerop18's Avatar
could it be that no one has tried this on ob2 yet and just dont know where to connect the plug? would it work if someone figured out the obd2 and hooked up the plug to it?
Old Dec 8, 2004
Our OBD2 ecus won't work with it. The way it is set up is a lot more complicated than previous versions.
sesi
Oct 1, 2015 02:03 PM
Cam Diaz
Sep 29, 2015 07:17 PM
curaze
Sep 22, 2015 08:27 AM
charmon4815
General
Sep 22, 2015 08:00 AM
duhwubwub
Sep 10, 2015 11:00 AM
