Best upgrade for a T3?
Old Nov 29, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Hi, the turbo that came with my SF kit (T3 super 60) is still suffering from the oil problem
I was thinking in case if I get myself another turbo, what are the possible choices, that would bolt on directly to the current setup (manifold & downpipe) ??? If I am spending money I can spend a lil extra to get something better.
In my little research I came across the Garrett GT-30R. Would this be a direct replacement for a T3? Any other suggestion? Thankx
Old Nov 29, 2004
dezod's Avatar
7thgen Power Maker
T3/T04 E
NICE UPGRADE RIGHT THERE!
Old Nov 29, 2004
Ahtasham's Avatar
Would that be a direct bolt on?
Old Nov 29, 2004
civic01vtec's Avatar
Originally Posted by dezod
T3/T04 E
bout the best you can do for our d17's
Old Nov 29, 2004
dezod's Avatar
7thgen Power Maker
Yes sir.
Old Nov 30, 2004
Ahtasham's Avatar
What do you have to say about this:
Garrett GT30R Dual Ball-Bearing Turbos
Supports up to 500 hp! Dual ball bearings allow for higher efficiency and much faster spool up. Compressor: 76.2 mm, 56 Trim, 0.60 A/R. T3 style turbine. An excellent high-power bolt-on upgrade for any T3 turbo. More power and less lag at a higher efficiency than a T3/T4 hybrid turbo.
(Reference: http://www.turbocalculator.com/view-...ct=002-001-007 )
Old Nov 30, 2004
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
i second that t3/t4 hybrid too much lag
Old Nov 30, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
HKS chargers
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
Depending on model, trim, displacement of the motor it's on...
Old Nov 30, 2004
well yea but in general a t3/t4 hybrid is not going to spool as fast as a t25BB or a KKK03 even though no one is their right mind is going to ever buy a KKK03 for a honda...i dont even think it would fit, but yea your right its all relevant on the application
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
well yea but in general a t3/t4 hybrid is not going to spool as fast as a t25BB....
TRUE! But a hair dryer T25BB @ 8 PSI is not going to put out nearly the power a T3/T04 E would on 8 PSI.
Old Nov 30, 2004
lol yup.....thats the thing with turbos....do you want power at a constant stream even though it wont be that powerful or do you want a rush of peak power....again depends on the application, on the street i would want a t25BB but on a high speed track thats when that hybrid comes in super handy
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
All depends on where you want power band placed. That T25 power maxs out at circa 4000 RPMS.....The T3/T04 will begin power there....Not to mention 95% of your honda racing is done at RPMS higher than 4000 RPMS.....we all know hondas can't move from a dig..............in comparison to say a 5.0 Stang.
P.S.-I am building a TT 5.0 Carb'd Mustang in Spring. I am excited.
Old Nov 30, 2004
Yup just like i said, my friend used to a have a 5.0 moderate work done it, crazy whiplash effect. Tell you the truth if i could have any moderatly priced car now...it would be the lotus elise. If only it ran on a honda engine instead of a toyota....i dread toyota....but i respect them
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
TOYOTA engines are not that bad..............My mother has had a Camry for 8 almost 9 years and I used to BEAT on that thing when I was growing up. I used to beg her to borrow it so my buddy Sean and I could go racing in it when we were 16-17. Good times back then............Life was so simple.
I also know many of people that have had older Toyotas and for 120-150K miles......No major problems.
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
Yup just like i said, my friend used to a have a 5.0 moderate work done it, crazy whiplash effect....
That's RAW Torque at it's finest. I love that feeling. Dumping the clutch at 3K and getting the *** end to kick out....tires spinning....pushed back into the seat........you feel it in the floor boards.........ahh man do I miss power like that.
Old Nov 30, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Agreed. However, 8psi is 8psi. Doesn't matter what turbo its coming from.
Its all about efficiency.
Old Nov 30, 2004
gotti's Avatar
Couldn't be more wrong. A bigger turbo presses MORE air into the engine at 8psi. A smaller turbo will press less air into the engine at 8psi.
Old Nov 30, 2004
dezod's Avatar
7thgen Power Maker
true!
Old Nov 30, 2004
TheSmuggler's Avatar
LOL, sorry I just read this and someone said something about Tripple K's. Man o man if someone ever got on of those on our civics.... it would be over! lol
*Back to your regularly scheduled postings*
Old Nov 30, 2004
Ok, lets look at this from a mathematical standpoint.
Airflow through an engine takes no note of turbo size. Only pressure.
Airflow rate=(CID*RPM*.5*Ev)/1728
Say we have a 2.0L engine. 122 Cubic inches.
122*5000*.5*(say 80% effieciency)/1728=141CFM.
Say we are running one bar of boost.
Airflow rate = pressure ratio * NA cfm
2.0*141=282CFM under 1 bar of boost.
Where in there is what size turbo to determine what "pushes" the air through? It doesn't "push" it simply creates pressure in the manifold.
Old Nov 30, 2004
naww course not they make good japanese engines....id prefer a honda though.
Old Nov 30, 2004
lkm's Avatar
lkm
Super Member
i still wanna hook up a leaf blower to the intake
lol, ill try that on the beater accord i have in the driveway
Cam Diaz
Sep 29, 2015 07:17 PM
AffliictiioN
Sep 16, 2015 02:21 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
KikAzz
Sep 4, 2015 12:36 PM
