Callin all fuel guru's
Old Nov 27, 2004
cdmx's Avatar
I read the fuel system faq, but now I would like to know what You guys have in your setup.
Is your setup working good?
I was thinking greddy emange and some extra injectors, would that be all I would need? Or do i need to add an inline fuel pump.
This good for up to 10psi?
Old Nov 27, 2004
civic01vtec's Avatar
I have SF fmu set-up. It works fine, runs a little rich. The pump is loud and tends to wear out fast. This occurs cuz the pump still runs when not in boost. Can easily be fixed by installing a toggle switch or pressure sensor in the charge pipe. It is a pretty easy set-up and is perfect for n00bs or those that don't wanna pay for dyno tuning.
I have a greddy e-manage and type s injectors that i will be installing in a few months. Problem with this is........you will need a wideband to street tune, which cost over $300. As Opto_isolator and Dezod have found out........there are a few kinks that need to be worked out.
IMO........the best set-up would be the e-manage, type s injectors and a complete return fuel set-up. A return set-up will run you approx. $600-$700. With this set-up, expect to throw down at least another $500 for dyno tuning. BTW.........even without the return fuel set-up.........you still should hit the dyno.
Old Nov 27, 2004
allmotor's Avatar
nor cal 7thgens
great info
Old Nov 27, 2004
btw.........i believe that andyman97 did a excellent write up on fuel set-ups a couple months ago..........search for that.
Old Nov 28, 2004
cdmx's Avatar
I tried searching...i guess i need to search harder
Well how about some more boosted people!
Old Nov 28, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
Well depending on what Dezod throws down for their fuel system, I am going with rsx injectors, and the e-manage to mess with my fuel. Most definitely gonna get it dyno tuned to make sure im not running too lean or rich.
Old Nov 28, 2004
my bad, he talked about detonation
Barney did the fuel FAQ
http://www.7thgencivic.com/forums/sh...uel+system+FAQ
Bman2212
Sep 2, 2015 11:49 AM
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
