E-manage advice, some problems tunning.Pls
Old Nov 25, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Happy thanksgiving,
Car is boosting e-manage working, but,
The main problem is the coil fuse is burning often, then the car dies, when fuse replaced, as soon as we turn the key to the on possition it backfires even thought the engine not running.
Any feed back would be appreciated.
Old Nov 25, 2004
supermex's Avatar
bump
Old Nov 25, 2004
opto_isolator's Avatar
Originally Posted by Supermex
Happy thanksgiving,
Your rotary switches are set incorrectly (probably 4-8-B) - make sure it is set to 4-8-C. The older honda's used a different set up than the current ones - the older setting of 4-8-B will burn the fuse out....
Old Nov 25, 2004
supermex's Avatar
I'll pass this along to the tunners.
vmunoz
May 30, 2015 09:31 PM
DouglasTheGreat
May 27, 2015 11:23 PM
EricKnudsen
May 27, 2015 08:22 PM
crowtoo
May 11, 2015 06:50 PM
Jigee
May 9, 2015 11:18 AM
