does a turbo
Old Nov 21, 2004
djpolanco's Avatar
djpolanco is an unknown quantity at this point
does a turbo
he i nned help a bit i wana put a turbo on my 01 lx but im not sure will the turbo **** up my engine.. or i can put the turbo and do what to my engine so it wont get **** up
Old Nov 21, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
turbo is going to artificialy increase your compression by stuffing the air into the engine. Its sort of like making the engine bigger without actualy making the engine bigger if that makes any sense. So yeah it will wear things out earlier but good parts, lower compression and modest boost will minimize the bad effects. one of the best things about civics is that stock engines can be had really cheap so if you blow it up you can always find a replacment engine.
Old Nov 21, 2004
S2000man01's Avatar
O RLY
you should be able to run low psi on stock internals no problem. honda makes the parts beyond spec. even the stock crankshaft can take 600+ hp.
Old Nov 21, 2004
exclusive_vtec's Avatar
Old Nov 21, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
well, you can do certain things to help out the car.... like spark plugs, injectors, high octain fuel, and synthetic oil..... things should be ok.... but obviously if you floor it all the time... well, things will break eventually.
generally, back in the 80's, turbo cars dont last as long as N/A cars.... but things have changed I guess.....
Old Nov 21, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
8 lbs. should be the maximum for a manual transmission. check oil and fluid levels weekly. use sythetic oils. hopefully in the future aftermarket companies will offer stronger internals.
Old Nov 21, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
/\/\???? Like pistons....TSI 9.5:1 forged @ sportcompactonly.com.....and rods?....crower makes forged rods for us
Old Nov 21, 2004
Havok2k1's Avatar
Wicked Pissah Admin
turbo FAQ is your friend
http://www.7thgencivic.com/forums/sh...d.php?t=174045
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
