Turbo chargers
Old Nov 7, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
Post Turbo chargers
what the difference between regular Garrett chargers and HKS gt chargers? i know the gt25xx hks chargers cost like 2k-2.5k.
Old Nov 7, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Size, spool up time, and mainly POWER!
Old Nov 7, 2004
Boosting Daily
6psi on HKS GT > 6psi say on a Garrett T20, 25, 28, 3
Old Nov 7, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The difference is the housings. HKS uses garrett CHRAs.
Old Nov 8, 2004
lkm's Avatar
lkm
Super Member
explain in noobie talk plz
Old Nov 8, 2004
The compressor wheel, bearing section, and turbine assembly is called a center housing rotating assembly. CHRA. The housings on the end can be removed and modified which is what HKS does.
Old Nov 8, 2004
dezod's Avatar
7thgen Power Maker
HEY someone else who knows turbos! You got rep for that.
Old Nov 8, 2004
I know lots. Thanks
Old Nov 8, 2004
dezod's Avatar
7thgen Power Maker
I know lots. Thanks
Good for you. Knowledge is power.
Old Nov 8, 2004
lkm's Avatar
lkm
Super Member
sooo. is a KKS gt charger worth the pennies to buy or just stay with a regular garrett charger.
i might get the turbo first then later when k20 are cheaper swap it out. im looking to make 200whp with d17 and atleast 300whp with k20. things i consider *very very very* important are turbo spool times to full boost. also, do they have a good resale value.
the most important thing is lower lag and more power. i wanna build a rear mount turbo mainly for the easy install.
edit: i can also learn to build it front mount but im looking at rear mount for the unique sleeper look.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
MamaBear2015
Sep 7, 2015 06:00 PM
justcruzin125
Aug 11, 2015 09:09 PM
