Fuel rail.
Old Oct 30, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Fuel rail.
Im making a return fuel system for my civic, and i need to know what kind of material our stock fuel rail is, so that i can weld a fitting onto it.
Please let me know.
Jeff
Old Oct 31, 2004
tfnaaf's Avatar
BLDNPSI Mod
Please let me know.
Jeff
It's steel, i picked up a fitting for $ .91 and paid $30 to have it tig welded. BTW it looks much better in person, that picture makes it look like it was stick welded Others have had them brazed on also and had good results
Old Nov 2, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
thin steel tig welds like crap anyways dont sweat those welds, they are fine. you can use a bypass regulator and not need the fitting in the rail though. the return line comes out of the regulator aeromotive sells one. way easier and the regulator is way better.
Old Nov 2, 2004
opto_isolator's Avatar
Dude - this is what Aeromotive says on their web site:
2.) I'm trying to plumb my stand-alone EFI regulator properly, where do I put the regulator, before or after the fuel rail(s), and what ports do I use?
Unlike a standard or “dead-head” carb regulator, which controls pressure between itself and the carburetor, the bypass regulator controls pressure between itself and the pump. Therefore, the correct EFI regulator location is after the fuel rail(s) whenever possible, promoting the required fuel pressure, flow volume and velocity through the fuel rail and to the injector inlet, at all times. Most Aeromotive EFI regulators have two inlet ports, one on each side, and one bypass port, on the bottom. Either inlet may be used with a single fuel rail engine, both inlets with a dual fuel rail. Any unused inlet ports must be blocked with the appropriate port plug. The ideal flow-path is: out of the fuel pump, into one end of the rail; out the other end of the rail, into the regulator side port(s); out the regulator bottom port, back to the tank at the top. Dual rail applications should employ a Y-block to split the supply line before entering the rails, then individual lines are run from the opposite end of each rail to each inlet port on the regulator.
If you don't use a fitting, I don't see how the rail can be BEFORE the regulator....If you hook it up as you describe - issues may exist. This is how they recommend connecting this thing....
Old Nov 2, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I've seen people tig weld cans together. Its all about control.
Old Nov 11, 2004
Crackhead79's Avatar
suscribing to thread, good info guys... ...oh and and BTW if you go with this set-up, and I am gonna be using a D16Y8 manifold anyhoo, if you do have the Aeromotive Fuel Regulator on the outlet side of the rail, would you still need it if you have the Vortech FMU? I mean don't they both regulate fuel pirssure and the other reacts to boost?
Bman2212
Sep 2, 2015 11:49 AM
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
