turbo timer
Old Oct 27, 2004
jawn_myek's Avatar
jawn_myek is an unknown quantity at this point
turbo timer
sorry i dont know what forum to post this on so dont flame...
i was wondering.. will any turbo timer work on an N/A vehicle?
thanks.
-jawn
Old Oct 27, 2004
prawdigy's Avatar
prawdigy is an unknown quantity at this point
wuts the point of it?
Old Oct 27, 2004
jawn_myek's Avatar
to cool down the engine.. any car even a non-turbo car should be cooled down, especially if it is ran hard.
Old Oct 27, 2004
exclusive_vtec's Avatar
turbo timer shows u the psi.. and what boost ur runnin how is this goin to help an n/a setup? and a civic? its useless dont waste ur money on it unless u got a turbo
Old Oct 27, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
it will work on n/a or f/i. but i don't see a point of getting one. if you have a turbo or heavy mod, maybe yes.
Old Oct 27, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
All Turbo Timers are designed to extend a turbocharger's life by allowing the engine to idle for a pre-set amount of time after the ignition key has been turned off and removed from the key cylinder. This permits the engine oil to circulate through the turbocharger bearing housing, drawing heat out of the bearings and impeller shaft to lower the temperature to a safe level before the engine is shut down. Why would you need one if you dont have a turbo???
Old Oct 27, 2004
Blueboi105's Avatar
Blueboi105 is an unknown quantity at this point
??? what are you talking about? I have the Apex'I TT.. they dont tell you how much boost you are doing.. you got it mixed up man.. all it does is lets your engine cool down..
my TT displays: A/F , 02 , Volt and the timer count down..
You dont need one unless your going turbo or have turbo.. But on the box it says for N/A or Turbo.. but they are refereing to a fully built N/A car.. i guess
Old Oct 27, 2004
Got Boost???'s Avatar
I think some HKS turbo timers dispay boost, maybe thats what he was talking about.
Old Oct 27, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
I'm going to be the one guy not to jump on the flaming bandwagon.
He is really looking for a convenience part - he wants the engine to idle for a preset amount of time after the key has been taken out (and he went inside or whatever).
Yes, it will work. I have installed two personally at work. And yes, it's a great idea. I would reccommend one to anyone who has any kind of internal combustion engine. I would estimate that it would extend the life of your block by 10 to 20 thousand miles. If you think about it, it makes perfect sense. You're allowing a ton of hard-used, red-hot parts to warm down rather than go from red-hot to ice cold (ignition off). That's why if anyone here has any First Aid training you would know that with a burn victim (hot coffee cup, etc.) you are supposed to run the injury under cool water, not HOT water. Same thing goes for hypothermia...
Every single pro N/A competitor uses a device like this, it's just not called a turbo timer. It's called warm-up and cool-down.
Old Oct 27, 2004
jawn_myek's Avatar
thank you..thats exactly what i was thinking.. how hard is the install of say the apex timer?
Old Oct 27, 2004
it paid 2 hours, took me and a friend 1.5 the first time (second went in 45 mins)
Old Oct 28, 2004
Titleist71's Avatar
in all actuality, the only time you would really need to use a turbo timer is if you were pushing 35psi or more of boost and when you get out of the car and look under the hood you can look through the exhaust manifold and see the block. Thats when things are hot and need to be cooled down in a controlled manner. Shutting the car off and sudden cooling will warp metal and even crack it....at those high temps. Our cars will never even see 25 psi. Yes it's cool to have but not necessary. The turbo will probably outlive the motor and it's internals anyway. I have a GReddy Full Auto Timer but I don't think I'm gonna use it. I'm only pushing 6 psi. If you really beat on your car bad...well you may want to use it.
Old Oct 29, 2004
step 1. drive car.
step 2. park.
step 3. open hood.
if your motor is hotter than the outside air, it's a good idea to cool it off. you're correct about the warping and cracking...doing it at our stock temps will probably never be a huge problem. but lots of little problems add up quickly.
Old Oct 29, 2004
Titleist71's Avatar
normal driving will make your motor hotter than the outside air. When was the last time you were outside and it was 250 degrees out? LOL.
Old Oct 29, 2004
civic01vtec's Avatar
when i was n/a i let my car cool down all the time........it will help prolong the life of the engine.
Old Oct 29, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I say its a good idea for anyone whos interested in doing it. It does make a lot of sense.
Old Oct 29, 2004
Titleist71's Avatar
totally, I especially let the car warm up. Everymorning I let it idle for a godd solid 2 minutes before I give it any gas. I basically let the car do it's own warm-up and when the RPM's drop then I know it's up to temp and ready to drive.
Old Oct 29, 2004
XxJDMCivicxX's Avatar
Ok I got a question since were on the topic. Ppl say you don't wanna let it cool for too long cuz oil might stay in the turbo and bearings if it's been idling too long right? Well since there are presets how long do you know to let it cool for 30 secs,1 min, 1 min 30 (Each time you drive your car you drive it different so its variable)? Will a couple of extra seconds matter than much for let's say preset one 45 secs to preset 2 1 min. And are there any that will shut off when the ideal temp is reached (when cooling down) either by setting manually or automated?
Old Oct 30, 2004
ummmm............there is no set time for letting it cool down. I mean, there is no need to let it cool down for 30 min.........but oil in the bearings is what u want and no matter how long u let it cool there will be oil in the turbo.
Most timers allow u to set it for a specific minute or u can set it to shut off relative to how long u were driving..........hours wise that is.
Old Oct 31, 2004
exactly my point. I was trying to get it through some thick heads that you need to cool your car down after every drive.
how do you think the members of the mercedes million miles club did it? certainly not by driving hard and then running inside after shutting off the car immediately.
Old Oct 31, 2004
Titleist71's Avatar
What! We aren't driving race cars here buddy. HAHAHA. If you dirve the car really hard its gonna be hotter than normal driving temps. Get it? Man, you must waste alot of your time sitting in your car letting it cool down. So that's everytime? Even with normal driving? When I drive, If I go into boost several times then I let it cool down. If I don't boost at all then I just shut it off. Remember our cars aren't making 1100 whp and pushing 42 lbs of boost. LOL. Oh ya I do have a thick head.
Old Oct 31, 2004
I wasn't exactly referring to you with the thick head. If you drive your car harder than usually you need to let it cool down. How long that time is, is up to you [especially if you have a turbo].
Using a turbo timer or allowing the motor to just run at idle allows the oil to run through the system a few more times...with the motor at idle that fresh oil is very cool, allowing the bearings in the turbo to cool down before shutting the car off - bringing the temperature of the turbo slowly down rather than to a screeching drop in temp. For N/A cars, it's important to let that oil run through a few more times to cool down the bearings in the motor.
Old Oct 31, 2004
Titleist71's Avatar
Yes...you are correct! And, it's ok to call me thick headed.......I have come to accept it. Hell, my mom even called me cold-hearted once.HAHAHAHA.
Old Oct 31, 2004
lol. same here
Old Oct 31, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
I have the Greddy Turbo Timer and can agree that it is useful for a NA setup, maybe not as much as a turbo set-up. But the logic is there, after driving your car hard you let it cool down makes perfect sense. These are engine parts rotating at hundreds of RPM, they get hot...and if your pushing your car and then you just shut it off that's not too good.
PLus the part you can find for like $50 so go for it!
And that installation isn't that hard, it's a total of about 5 wires. COnstant Power, switched power, ground, parking brake, and ignition, and speed sense if you'd like.
Old Oct 31, 2004
amen.
turbo timer for N/A
turbo timer for turbo application
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
