Which Engine?
Old Oct 23, 2004
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Which Engine?
Ok I just read the swap thread in here but im still confused... for a newb like me which engine swap would be the easiest for me to handle...D18C5 or the K20. and also everyone says K20A3 or something like that around my home...is that even an engine???? BTW I know a guy who works at a factory that can get me either of those engines for about 1,500... help please (please no flames i already admitted im a newb...)
Old Oct 23, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
D18C5????
Only legal swap is the K series.
A K20A2 would be the best/easiest. It is the RSX-S engine.
Old Oct 23, 2004
jeffsta17's Avatar
Emissions
is it only the legal one because of emissions or what???
Old Oct 23, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
A motor swapped into a vehicle must be the same age or newer than the vehicle it is going into.
Federal law.
Old Oct 25, 2004
HondaLuver's Avatar
Its a celebration bitches!
say you have a 01 civic, you can swap a 01 gsr, or type R engine, made in 2001. but if i have a 02, there are no more bseries... so you can
t swap
Old Oct 25, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Anyone know what a d18c5 is?
Old Oct 25, 2004
dwi's Avatar
dwi
dwi is an unknown quantity at this point
k20a2 is big bucks so happy spending. you're looking at $3,000 to $4,000 for everything....tranny, engine, ecu, etc. and thats w/o labor. i'm telling you, if u wanted a fast car, you should have gotten one.
Old Oct 26, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
K20a is the best - Integra Type R - 220hp
K20a2 secound best - Acura RSX Type S -200hp
K20a3 third best - Acura Base - 160hp
Old Oct 26, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
It would be expensive to swap a K20a. Just remember the engine alone is about 5k & plus parts are hard to find
Old Oct 26, 2004
jeffsta17's Avatar
Like i said in the original post I can get the engine off a friend for 1,500 and everything else I need but im thinking I will just sell my civic in a year or 2 and then buy something that moves.
Old Oct 26, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
hey if you can get a motor for that much hook me up with one i will give you 2000 just for finders fee. if you can i would prefer the k20a2. lol thats the us rsx-s
Old Oct 27, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
If you're looking for the easiet swap, i'd say, rebuilt D17 long-block from truehonda.com
If i'm not mistaken, i believe you can still use your current motor mounts, ecu, wiring, ect. Plus the long block being rebuilt should hold a nice amount of boost.
JMO
Old Oct 27, 2004
Boosting Daily
Also its a type r motor, built and designed for N/A. High compression pistons= lesser positive response to boost.
Old Oct 29, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
There Is Not Such Thing As A D18c5 What U Mean Is B18c5 Thats The Udsm Type R Motor B18c1 Is The Gsr And A B18c Is The Jdm Motor A K20a3 Is The Usdm Si Engine And A K20a Is The Type R One, A K20a2 Is The 01-04 Type S Motors And The K20z1 Is The New 05 Type S Motor... Just Info
Old Oct 29, 2004
wrussi's Avatar
Also If U Get A K20a Ur Better Off Doing An All Motor Setup.
But If You Go With Turbo Get A K20a2 Because Parts Are Cheaper And Easier To Find Here On The Us
Old Oct 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
actually high compression pistons are more responsive to boost ... but also more prone to detonation
Old Oct 31, 2004
LoganK's Avatar
LoganK is an unknown quantity at this point
if you can get me a k20a, ill gladly give you $2000 for it.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
