SF Turbo Installed ... Pics/Review etc inside
Old Oct 19, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Hi Guys, after two days of hard work I finally got the the SF turbo kit installed . It wasnt as easy as a 'bolt on kit'. Had to fix a few mistakes made by SF which took most of the time .
I have loads of pics in my camera but right now I am too lazy to upload them. I need some serious sleep. Also, I'll only upload them if you guys really want to see them. So let me know.
I'll be posting up details on installation plus some useful info regarding it when I get some free time. For now I am leaving you guys with a picture of the first thing I installed from the kit.
Old Oct 19, 2004
RedDragon333's Avatar
nice, more pics tho. What is your overall thought of the kit?
Old Oct 19, 2004
04vic's Avatar
04vic is an unknown quantity at this point
pics and comments please...
Old Oct 19, 2004
gotti's Avatar
you're missing a ground wire ;0
Old Oct 19, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
We need pics!
Old Oct 19, 2004
v8eaterokv6's Avatar
i have a new home do u
pics and a review would be nice. what kind of problems do you speak of
Old Oct 20, 2004
Ahtasham's Avatar
Dont be so sure buddy ... I had to relocate it
Old Oct 20, 2004
Ahtasham's Avatar
Ok Guys here are a few more shots of the installation.
Old Oct 20, 2004
Ahtasham's Avatar
And a few more .....
Old Oct 20, 2004
Ahtasham's Avatar
ISSUES/PROBLEMS FACED DURING INSTALLATION
First of all the downpipe that came with the kit touches the AC line (pipe). Which could become a major problem coz of the heat. Therefore I had to shift the AC line a lil further. The oil drain fitting provided with the kit is no good. I had to make my own fitting by using parts from the scrap shops and then welded it to the oil pan. So far there are no leaks. SF didnt send me the drain oil connector of the turbo .... so it was off the scrap shops once again. After much effort finally got the main unit (manifold/turbo/wastegate/downpipe) hooked up with the oil lines in place. All this took half a day..... to be continued .......
Old Oct 20, 2004
deciuss's Avatar
Boosted Auto
i tryed to do mine had to take it to a shop after some things where not right. the ac thing is touching the manifold a mettle part on it but i thought that would not be a problem ac worked on the car still after driving for over an hour
Old Oct 21, 2004
Ahtasham's Avatar
I'll be careful with that if I were you coz a friend of mine had the same issue on his 6th gen civic. After a few hours of driving in the heat with the AC on, the pipe caught fire and messed up a lot of things. Thats why I made sure to fix up this problem asap. I think you should also look into it as well.
Old Oct 21, 2004
Ahtasham's Avatar
ISSUES/PROBLEMS FACED DURING INSTALLATION (Part 2)
The second step was to hook up the intercooler and intake piping. The piping though worked out pretty good at the end but was quite difficult to put in at the beginning. The working space is really tight and you really need to get under the car if you want to do things right. The major problem I had (and still have to some extent) with the piping was the elbow that connects to the throttle body. It kept on touching the hood. I had to cut the connecting rubber hose step by step to see where it sat properly. Now I have the elbow touching the throttle body and the tip of the BOV still makes a little contact with the hood. But one reason for that is that I have CB hood that is lowered in the middle as compared to the OEM hood.
Next came the fuel setup. I have a lot to say on this but right now I have to get back to work ....... so ..... to be continued ........
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
Supramk3
Jun 11, 2015 11:13 AM
Youshoe
May 22, 2015 09:36 PM
