Turbo dripping oil...
Old Oct 11, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Red face Turbo dripping oil...
So i just instales another engine after i blew the shitt out of my stock, one and now the probnlem is my turbo smokes like hell one it fully spooled up, my mecanich told me it that i ****ed up some kind of rings in the turbo, or bearings or something, does anyone know where to get an averhaul kit for a T3 AR.60 that comes with the SF kit, i would really apreciate the help...
Old Oct 11, 2004
Also if the car stutters under boost would it be that the Missign Link Filter is dirty, and what can i clean it with....
Old Oct 11, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
You can't just "overhaul" a turbo. It has to be rebuilt and balanced. There are a couple places to get it rebuilt, turbochargers.com I think does it. cheapturbo.com does as well.
Old Oct 12, 2004
civicskater's Avatar
Chicks dig my scent
rebuilding turbos is kinda expensive, but i definatley say you're seals are shot, check your charge piping and see if you have oil in there and that'll let you know. But as 4drcivic2k1 said...check those sites for reuilds, good luck
Old Oct 12, 2004
Si, if its, just the seel there will be oil in the charge piping.. oks thanks,....
Old Oct 12, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Is there any warranty with that turbo?
Old Oct 12, 2004
PunkingCivic's Avatar
I need TP for my bunghole
does the turbo have a warrenty?
Old Oct 12, 2004
No i bought the kit used from another member...........
Old Oct 12, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Did you use the same oil pan as before? If your oil drain is too low in the pan, your turbo will smoke like crazy.
Old Oct 12, 2004
Catalyst's Avatar
use brakleen on the missing link. happened to me once on my car when i drove off without my dipstick.
Old Oct 12, 2004
NO i used a new oil pan i it has a little to much oil, but the turbo is dripping fromwhere you attach the downpipe to the turbo, so it still may be that i have to much oil...
and i don't think i can get Brakleen localy, would any kind of degreaser work.....
Oh, and if the return line was a little bent could that cause smoke also???
Old Oct 12, 2004
Catalyst's Avatar
The return line has to ALWAYS go down hill and cannot be kinked.
With the new oil pan, was the drain all the way at the top of the pan?
And just about any degreaser would work. Carb cleaner would also work.
Old Oct 12, 2004
opto_isolator's Avatar
Huh? Are you talking about drilling the hole above or below the baffle in the pan? Mine is below the baffle....
Old Oct 12, 2004
civic01vtec's Avatar
mine is above and works fine
Old Oct 12, 2004
Well the car continues to stuttuer once i get into 3+ psi, the engine i got was from a rolled over car, so could the Missing Link be Dirty inside and could that cause the stutter,
or coud it be a roblem with the boost controller, since when it was in auto program mode, i dint go all the way to the designatedPSI, and could anyone help me out on how to program a damn GReddy E-01
thanks......
Old Oct 12, 2004
Also how much Vaccum should he car read at idle.... cuase mine varies from 10 to 9.5 psi of vaccum........
Old Oct 12, 2004
Chicks dig my scent
it could be both of those...when you're car goes over 3psi does it flutter back n forth between psi? definately check your turbo though since its dripping oil, even if it means taking it apart, just be careful with the turbine, was size line are you using on the feed line?
Old Oct 13, 2004
i dont know the size, but its the one SF provides with the kit.........
Yes he car fluters back n forth between psi, and only on WOT will it go past that but not by very much.....
And what vaccum reading does everyone get on idle.........
Old Oct 13, 2004
Thats not PSI of vacuum, its In/Hg.
Old Oct 13, 2004
ok but how much should it read, cuz if it to high might have a boost leak.......
Old Oct 13, 2004
It varies, I think the helms says about 14 in/hg. (I think, don't quote me on that)
Old Oct 13, 2004
but it would be differe once boosted rigth.... cuz mi Boost controller reads -10 psi on ide......
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
justcruzin125
Aug 11, 2015 09:09 PM
