MODS to 300hp??
Old Oct 11, 2004
exturbo6's Avatar
MODS to 300hp??
i was wondering what i would have to do in order to get around 300hp??my turbo kit will be getting installed soon..but thats not going to do it..lower compression pistons. rods. whats else?? cause by the spring i want my car to be atleast 300. my friend was telling me to get a crank pulley cause they add some with a turbo but i was reading abotu them on here just to see what poeple had to say and that is a no go..dont need problems with that..thanks
Old Oct 11, 2004
jyoung's Avatar
jyoung is an unknown quantity at this point
what engine...
Old Oct 11, 2004
Spider883's Avatar
9K Redline Owns U
are you talking crank hp or wheel hp.. big difference
either way you need a fully built engine
Old Oct 11, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
^^agreed
Old Oct 11, 2004
jttegx's Avatar
OMNES AD UNUM
on a d series... its gonna be real difficult.
why care for hp #'s though? times are much more impressive to hear than just numbers.
Old Oct 11, 2004
exturbo6's Avatar
i have a d17...well you need hp to make good times no??? im talking to the wheels.
Old Oct 11, 2004
exturbo6's Avatar
so if i need a fully built engine..what would that consite of and how much would i be looking at?
Old Oct 11, 2004
import2nr's Avatar
awd pwnz j00
PnP, build it, more boost, bad *** tuning
edit: built engine... pistons/rods, turbo cams, valve springs etc
total price w/o turbo probably around 3-5k if its done right with quality parts.
also i would look around the FI section b.c this has been discussed there with several members like opto and never forget to search
Old Oct 11, 2004
NEWARK-aveP-NJ's Avatar
NEWARK-aveP-NJ is an unknown quantity at this point
i personally doubt that you will be able to run a d17 at 300whp safely/daily
Old Oct 11, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
to get your civic to 300hp in 2 easy steps:
1. sell the civic
2. go buy a 300hp car
Old Oct 11, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
300WHP? Thats a pretty high goal. To be safe, fully buit, but even then, the results may not add up to 300WHP. A swap wuold be a better choice before turboing.
Old Oct 11, 2004
robbclark1's Avatar
Retired suspension supermod.
I don't think the chassis can handle 300hp either. Talk to guns, he is pushing around 240 to the wheels now. It will cost you, i will tell you that much.
Old Oct 11, 2004
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
i believe catalyst has 300whp, you may wanna try and talk to him.
Old Oct 11, 2004
exturbo6's Avatar
thank you! i have the turbo kit in my room...who makes a good cam shaft for d series motors? je pistons? whats a good set of rods? skunk 2 valves and retainers? theres a place that does PnP for under a G in CT i believe.
Old Oct 11, 2004
exturbo6's Avatar
did i miss anything?
Old Oct 11, 2004
pbfoot's Avatar
i second that. you have to think about more than just engine tuning when it comes to something like that. youre gonna have to reinforce the frame and the axles, which would add weight. and tuning the engine to get to where you want to be wont be cheap.
youre looking at head work, lots of custom work for the bottom end. chances of finding rods/pistons to suit your need that are already on the market for the d17 are slim. not sure if thats accurate anymore, but there are definitely not many choices tho. you might have to bore and/or stroke the bottom, or get a custom stroker kit. probably blueprinting the motor. chances of all this getting done by spring are probably not really realistic. i doubt you want the motor to blow up, and this isnt something you rush when you have so much custom parts made.
this is just the motor, besides that youre gonna have LOTS of things to worry about like computer, fuel delivery/management, cooling. good luck.
Old Oct 11, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
I just saw a 500 whp d16 on honda-tech. Pretty badass setup using a t3/t4 and running 33 psi. It can be done on the d17 to but for 300whp your going to need a descent size turbo like a t3 and youll need to build the engine (sleeves,pistons,rods...etc). Youll also need a good fuel system the rsx injectors and pump will prob be enough there are 300whp rsx's using the stock injectors and pump. Youll need something like an emanage and get the support tools so you can tune the engine. Theres alot of stuff youll need this is just a list of the basics cause if you have a kit and it doesn't have some of the key componets listed above you might want to rethink your descision.
Old Oct 11, 2004
import2nr's Avatar
awd pwnz j00
^^^^ w0rd (to Pbfoot's post)
Old Oct 11, 2004
exturbo6's Avatar
thank you for the advise...so what is the max hp you could get out of a d17 with doing all this work, not blowing the engine and being able to drive it daily?
Old Oct 11, 2004
audioefx3's Avatar
pbfoot i dont think any headwork would be needed on a built engine to hit 300whp. Also there are several companies making internals for our engines so dont post saying that custom work is going to be needed when i have a set of forged je pistons and eagle rods sitting hear infront of me that are made for our engines. If your gonna put 300whp to use in a 7thgen be prepared to beef up the tranny(cyro treated,steel syncros..etc), driveshafts, suspension, and brakes at least to handle the abuse and handle it safely.
Old Oct 11, 2004
exturbo6's Avatar
k thanks man..very helpful...i just want to see what i can do with this...cause i have a turbo setup waiting for install...but ill only be able to run stock boost which is fine with me..but idk i want to be able to aleast turn the boost up 10 psi..nothing too crazy..cause if all you guys are saying it will cost mad loot and im going to need all sorts of parts to make it work..i guess i should start off small and work at this car..so would i need to upgrade alot of parts just to run 10pd. of boost?
Old Oct 11, 2004
exturbo6's Avatar
how much did it run you for the pistons and rods? i could just drop those in a turn the boost up a lil? or is there more to it then just pistons and rods?
Old Oct 11, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
still depends on what all you do. I am driving around on ~235 whp daily. Its a relatively low boost setting (7 psi) and just well tuned. I pre-program in a safety, so if i go past my 8 psi preset, my car goes soo rich it tries to die. So boost spikes are not a problem for me. When i go to the track, i load in my race-tune, turn the boost up to 11-13 psi, and run bottom 13's. With the new intake manifold and throttle body we will be coming out with soon, i hope to break 12's. My goal is a mid 13 second pass on my street tune.
Now i know as a fact that you can take the stock motor, port the head, and put some boost to it with a radical tune and make 300 whp. But i really wouldnt recommend it more than 1 time. Its pretty hard on the motor.
If i were to build the motor for a daily driver, it would include:
sleeves
rods
pistons
head studs (since you already have the motor apart, why not?)
port work
cam
cam gear
pulleys
intake manifold
throttle body
fuel rail
some sort of EMS
Good STREET clutch (not a 6 puck)
and some tires that dont hook up too well
I know that the tranny will start to make odd noises if you have a combination of lots of power, aggressive clutch, and sticky tires.
Old Oct 11, 2004
Spider883's Avatar
9K Redline Owns U
Just wait for Supermex (Hector) to finish his turbo.. he already has fully built internals and head work.
Old Oct 11, 2004
pbfoot's Avatar
hey man, i said i could be wrong, and even if there are internals on the market, theres maybe 1 or 2 places tops that make them, which i also said. so get off my case. and as far as headwork, he asked for advise/suggestions, i gave him my advice. you might not want to do headwork, but i think its neccessary...to each his own. im my opinion, if youre gonna put money into internals, why cut corners and leave the heads like they are. youre just restricting the engine that way.
and exturbo, i might be wrong again, but IMO it will be a stretch to have both a 300whp honda civic that is not only streetable but a daily driver.
Old Oct 11, 2004
exturbo6's Avatar
thank you very much....where could i get all different parts for the d17..ive been looking for them but cant seem to find any places that sell them?besides what i have already done to my engine
Old Oct 11, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Click here for the answer to all your questions
Save your self a lot of time.
Old Oct 11, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Originally Posted by Supermex
Thank you Super...
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
kmarcet
Sep 26, 2015 10:25 PM
ZoSoIV
Sep 17, 2015 07:17 PM
muniorbust
33
Aug 31, 2015 08:59 PM
