k im engine retarded
Old Oct 10, 2004
bake's Avatar
bake is an unknown quantity at this point
aight well ive been to the point that i can't take the exterior any further on my car so now im thinkin about the engine, i have an 01 ex auto, kinda been reading through the noob sections and it seems my steps should go tranny swap, then engine swap (k20), then turbo it, does this sound right or should i do it differently than that
Old Oct 10, 2004
civic01vtec's Avatar
i am guessing that you have a auto ?
therefore, if you plan on the a/t to m/t tranny swap, that is pointless if you are gonna swap a k20.
Old Oct 10, 2004
bake's Avatar
i have an auto yes, if i got the k20 y wouldn't i still need to switch the tranny
Old Oct 10, 2004
someguy's Avatar
someguy is an unknown quantity at this point
it all depends on what you want outta your car. but yeah, dont do an a/t to m/t swap if your going to do a k20 swap.
Old Oct 10, 2004
someguy's Avatar
you would need the tranny from the k20. d17's wont fit.
Old Oct 10, 2004
bake's Avatar
so k20 swap and k20 tranny, then turbo that would get me about where in the hp range
Old Oct 10, 2004
if you got at least 10 g's.....then go for it
i say you will be around 280whp
Old Oct 10, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yea the swap can be done, its fairly straightfoward. The K series engine is passenger side mounted, where as the D series is mounted on the drivers side, so the transmissions are not interchangeable. HOWEVER, you will need to add a clutch pedal. (which is simple enough.) If you need any help with the swap, let me know.
Old Oct 15, 2004
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
yea 10-15 k for this plan.... all easy but you need rsx front clip for parts or it will take forever, + alot of labor and other parts
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Jeeves
General
18
Jan 31, 2002 08:18 AM
Cross
Jan 6, 2002 01:31 AM
Blckcivic01
Dec 30, 2001 08:58 PM
supercivic01
South
Nov 30, 2001 11:27 AM
