hg blown, head warped?
Old Oct 7, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Question hg blown, head warped?
I just blew my headgasket. I also know some others on this site did too. Did you dudes get the head checked out to see if the head was warped or in anyway damaged? My dad damaged his head on his 86 supra when his hg blew and he said i might have an issue with mine. Most people that ive seen or heard on this site just replace the hg and go. But is the head damaged or did you get it checked?
Old Oct 7, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
it should only be warped if it was overheating for a while ...
Old Oct 7, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I did it three times. But never let it just overheat. As soon as it got a little hot I shut it down. Did it get hot and overboil or did it completely overheat and run dry.
Take it from me after a year of boosting. Double stack the headgasket to lower compression and use new headbolts torques down an extra 3-4lbs. I ran 14psi lean and mine held after I got smart about it and doubled up to lower the compression.
The stock headgasket is single layer and pops around 8psi. Use two leakless tripple layer Nippon headgaskets.
Old Oct 7, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
hey guns what do you mean by this
use new headbolts torques down an extra 3-4lbs?
Old Oct 7, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
The stock headgasket is now a Nippon leakless. Honda changed about this time last year. Before that, it was an organic/paper/crap gasket, now it's metal and rubber.
Old Oct 7, 2004
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
well check it with a strait edge or a true ruler put a fealler gauge in the gap and if its more than .03 send it to the machine shop to be plained
Old Oct 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
new head bolts, get them new everytime u take the head off, and then if u use more than one head gasket its going to require a different torque amount than stock, basically torque it down to stock setting the first time, then the headgaskets are going to matte together and require another torquing
Old Oct 8, 2004
guns's Avatar
Skyline R33
specs are 49lbs of torque on the bolt. I used 52lbs. No problems. I just used three steps. 20lbs, 30lbs and then 52lbs. Not oem specs but it worked
Old Oct 8, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
what does it mean when this happens?
Old Oct 8, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Just get the ARP studs,
they are reusable.
Ccoop87
Jul 9, 2015 03:26 PM
Hqly2001
General
Jul 8, 2015 04:07 PM
Bounddyy
Jul 8, 2015 11:22 AM
AaronSorenson
Jul 7, 2015 09:40 PM
ZILLA
Jul 5, 2015 05:24 PM
