sad day for the lx-t in okc, blown head gasket
Old Oct 6, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Post sad day for the lx-t in okc, blown head gasket
Ok, for the last few days my car has been overheating while at idle. I went to riceburnrEx`s house today to do a compression test, and found out that my hg is blown. 1) 185 2) 185 3) 160 4)185. So im in the market for a new head gasket. Just wanted to share my experience, if you have turbo civic and you havent blown the hg, it would be a good idea to get a new one any way, just my 0.03 cents.
Old Oct 6, 2004
civic01vtec's Avatar
how much boost u running and how long u been boosted ?
Old Oct 6, 2004
04vic's Avatar
04vic is an unknown quantity at this point
did you at anytime replace the head/headgasket or is it stock headgasket?
Old Oct 6, 2004
SODJAZERO's Avatar
since febuary, i instaled it valentines day, my gyrl didnt like that too much
Old Oct 6, 2004
SODJAZERO's Avatar
Its the stock hg.
Old Oct 6, 2004
someguy's Avatar
someguy is an unknown quantity at this point
ooohhh....do you mind if i ask what kind of numbers your running. also on what level of boost. you could pm me if you want....i wont post up the numbers if you dont want them public. its just i have an lx and want to see what kind of numbers these things put down boosted.
Old Oct 6, 2004
boost > women
Old Oct 6, 2004
SODJAZERO's Avatar
Just these last few months ive cranked up the boost from 4 to 6psi. At 4 psi i put down 155whp. So for the last, ide say 2 months i have been running 6 lbs. I have not gotten it dyno tuned at 6psi yet...(because of the **** that just happened) Ive heard that the 01-02 civics have a paper hg, the 03 and up have the aluminum rubber nippon gaskets. So with proper tuning i think they would stand less of a chance blowing the hg.
Old Oct 6, 2004
HyaBoosta's Avatar
dam. that sucks, I am getting a nippon leakless and arp headstuds before i install my kit.
Old Oct 6, 2004
SODJAZERO's Avatar
please do man, it will save you alot of trouble! Trust me!
Old Oct 6, 2004
opto_isolator's Avatar
How do you know its the HG and not the ringlands?
Old Oct 6, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Because compression loss would be more than 20psi with ringlands, and whenever we removed a sparkplug or took the compression tester out, we could smell and see (smoke) coolant leaving the #3 cylinder.
Old Oct 7, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
sorry to hear that bro.. thats a nice turbo you got..
Old Oct 7, 2004
SODJAZERO's Avatar
Hopefully i should get this taken care of by sunday, i hope...
Old Oct 7, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
Right now i am running a stock honda head gasket that i purchased after SCE gave me one of their .088" vulcanized head gasket that didnt fit (was made for a 00, figured i would give it a try). I run my head bolts at about 60 ft/lbs. And through all the testing we have done, and the 5.5-7 psi daily driving and 13+ psi racing (and one dyno at 16+ psi), i havent blown it yet.
Dave hickman claims to have gone 9's on the stock head gasket in his yellow race car.
Old Oct 7, 2004
Paper gasket wha? My 02 came with a metal one, same as the nippon leakless prolly. They looked the same anyway.
Old Oct 7, 2004
SODJAZERO's Avatar
^^^ Yah that wasnt concrete info tho. Thats just what i heard. Ill find out for sure sunday hopefully.
Old Oct 7, 2004
First to spool
The one I pulled out of my spare motor and according to Honda's part description was an organic paper combination gasket, which has since been replaced by the Nippon leakless. If you had an 01 or some 02's you might have the paper gasket, any after 02 or any you can buy at a dealership will be the nippon leakless.
Old Oct 8, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
overheating=blown h/g
crazy smoke=rings
or I could be wrong
Old Oct 8, 2004
SODJAZERO's Avatar
Thats just the thing:
the car only over heats at idle
No smoke or coolant drainage from the exhaust
No oil mixing in the coolant
The only way we knew for sure was the compression check. And the smell of coolant when we pulled spark plug number 3.
Old Oct 9, 2004
deciuss's Avatar
Boosted Auto
i just pulled my hg today for my failed turbo install. there was a paper thing but then also a metal one srug
mistermenphis22
Apr 3, 2016 08:06 AM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
