Emanage Help!
Emanage Help!
Hey I just bought an emanage from another memebr and i would love to know what is what. All i got was the main unit and injector and ignition harness. There is one that clips in the connector 1 spot and one that connects in the number 2 spot. which is which? and it also has a yellow inlet marked boost, what goes to that or is that only for cars that have a greddy turbo kit? There also a small black box that says greddy and has 3 wires coming out. Can anyone help me out since i have no directions with it? thanks
http://www.mohdparts.com/emanage/man...ual/index.html
Opto, do you know what settings would keep my car running smooth in stock form. I want to do the install before the turbo to make sure everything goes smooth at the install. I don;t want the car to run sloppy while I have it NA with the emange
this has been an atl01 production..
you probably wont need the little black box that says greddy on it, I know its some kind of sensor adaptor for the type S. Do you have the e-manage software? if not your going to need to get it to tune the e-manage.
opto_isolator
Engine Swaps
17
Jun 13, 2005 10:04 PM
