VAFCII+Turbo= Complications???
Old Oct 3, 2004
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
Exclamation VAFCII+Turbo= Complications???
Whats up guys, well heres a question for ya.
I have and apexi VafcII Controller (allows me to control fuel ratios) and i was in the market for a turbo..but i got to thinkin... would there be any complications to boosting my car. seeing as the apexi delivers +1% more fuel during Vtec? (even at 1% more fuel the apexi has given me a significant hp increase)
Old Oct 3, 2004
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
i heard that the vafc2 automatically advances ign. timing which would not be a good thing when boosting. but thats just what i heard
Old Oct 3, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Old Oct 3, 2004
down_'s Avatar
Originally Posted by STL01Civic
for all the time you put into correcting my spelling, you could have gave me an awnser
Old Oct 3, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i dont see how it advances the timing.. you dont hook it up to the spark plug coil control wires...
Old Oct 3, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
it advances the ignition as a byproduct of altering the map sensor signals. Youll be alright if do not alter the signal that much. If you alter it to much to try to tune your turbo d17 to say 10 psi you might run into some problems.
Old Oct 3, 2004
down_'s Avatar
Hummm.....well thats a bitc# .....i actually wanted to run up to 10 psi.....have any ideas on what type of problems.. i just got done looking at turbo kits and most offer a compleat kit w/ an apexi
Old Oct 3, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
hmm.. tried adding fuel on the damn thing and it wont
Old Oct 4, 2004
down_'s Avatar
adding fuel w/ your apexi??? do you have a turbo kit?
Old Oct 4, 2004
i got a turbo kit....vafc is working fine now... i forgot todo something minor.. no biggie
Old Oct 4, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
Under boost the map sensor is at zero already has the injectors all the way they are going to open. If you add too much to the map you will get a check engine light do to the ECU thinking there is presure on the map. Hard to explain. You can use the VAFC to take out fuel close the injectors but does not work to add fuel. The map isolator makes the map see 0psi of vacume. The VAFC alters the map signal to add fuel. I hope this makes sence. I have been using VAFC2 and Boost for a year. I think I kinda got an idea.
****Posted by GUNS sorry H-town forgot to log you out*******
Old Oct 4, 2004
correction... it works fine now
Old Oct 6, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Besure to use it only to fine tune, nothing more. Dont use it to lean out too much. It will add timing. Good luck. VAFC2 does work for turbo but only for fine tuning.
Old Oct 6, 2004
car runs fine without adjusting the vafc2.. im have rsx injectors so it pretty much stays in the "IDEAL" range of the a/f guage.. i just have it leaned out in the 1000rpm area cause its feeding to much gas there causing it to bog during idle.. but its all good now
Old Oct 6, 2004
civicskater's Avatar
Chicks dig my scent
all hondas generally run more lean at an idle range anyway (good ole ULEV) but that sounds good
Old Oct 6, 2004
yea.. it used to run more lean.. but when i changed the injectors out it started to run heavy rich and sometimes the car bogged at low rpms cause it had to much gas
Ziggy1999
Oct 15, 2015 07:56 PM
Jrosa
Sep 14, 2015 08:24 PM
streetglower
Jan 26, 2004 03:46 PM
white2K2EX
Feb 7, 2003 06:23 AM
