Turbo or Supercharger
Old Sep 30, 2004
spyder2333's Avatar
EM2/DC5/LS1
spyder2333 is an unknown quantity at this point
I have an 02 ex (auto) and I work for a shop called Ripp Modifications some people might of heard of it. They build custom superchargers for 6g72 Eclipse, 3000 GT, Lancer, Stratus, and the new Tiburon. And so on, from Vortech superchargers. Supossidly I heard they are making one for our d17's. Should I wait till it comes out, if it does come out or should I go turbo, I want either before next summer...If anyone wants more info its Rippmods.com
Old Sep 30, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
turbo fun to work with, and can create more power with our cars, I think superchargers are more for like v6 or v8 not for 4 bangers...thats just IMO
Old Sep 30, 2004
tigerclaw's Avatar
tigerclaw is an unknown quantity at this point
nash i think i might have to disaggree. i heard that in our cars they can swing well either way. but im just a noob and thats just what i heard around. i wanted to supercharge mine as well.
Old Sep 30, 2004
tigerclaw's Avatar
i heard that supercharging is better for a daily driver.
Old Sep 30, 2004
shmik1's Avatar
well if u dont know for sure if they're makin one, find out.. if its not 100% sure that they WILL be releasing one, then decide turbo now
Old Sep 30, 2004
NaSh123's Avatar
essentially they are both doing the same thing.....more air.....one helps you right off the line the other needs to get spooling and kicks in later....there are no superchargers for our car, as of now from what i know, i doubt anyone will make one but i could be wrong
Old Sep 30, 2004
WhiteCastle's Avatar
INFOOOOOOOOOO ON super chargers please!!!!!!!!!!
for the love of god please!!!!!!!!!
this is the best thing for autos in the world!!!!!!!
find out if they do!
Old Sep 30, 2004
abmerop18's Avatar
Jam out with your clam out.
they are not gonna do it so dont get your hopes up people. there is too much work involved in custom fitting a supercharger to make it financially reasonable over turbo.
Old Sep 30, 2004
dragoon's Avatar
superchargers, even smaller centrifugal types, are still nearly impossible to cram into our engine bay, even with extensive work. it's just not worth it. get over it.
Old Sep 30, 2004
Pharoh's Avatar
Bobaganoosh!
Are you sure a Vortech (if available) wouldn't fit? It didn't look that big in the 6thgen SiR
Old Sep 30, 2004
Spider883's Avatar
9K Redline Owns U
Ripp motorsports makes on custom built per car supercharger kits.. they dont sell kits they will only make it if u bring your car there and its not cheap.. the one i have seen they did on a 03' v6 eclipese was 8000 bucks.. not cheap at all
Old Sep 30, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
In the end... for the amount of money spent and the amount of boost run... turbos are faster and safer.
Superchargers are parasitic belt driven devices, turbos use energy the engine has already gotten rid of in the exhaust stream. Turbochargers (unless you get one that's the size of your pinky) will flow more CFM at a MUCH less heat level. More CFM=more power, and colder air=more power. It's not just PSI that makes power. Turbos have better gas mileage since you are not even in boost unless you're really on it.
True... superchargers have no lag, but then again, neither does a ball bearing turbo with a 2 step rev limiter, good boost controller, and a good driver.
Old Oct 1, 2004
like a t25bb spooled at 2300 rpms....smoking tires
Old Oct 1, 2004
spyder2333's Avatar
EM2/DC5/LS1
not true they have kits for tiburon, eclipse, galant, lancer ,i work there
Old Oct 1, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
Nicely spoken! Also I doubt u would get more than 25/30 horses with a supercharger. Takes power to make power in the case of superchargers IMO. On a big motor it gives more gains. Lets look at the SI (SIR) JR supercharger...seemed to be a dissapointment. I would put my money on a turbo d17 all day compared to a supercharged SI. That spyder guy with the 350 had a supercharged SI, and i think the main reason he sold it was the gains sucked with the supercharger.
Old Oct 1, 2004
someguy's Avatar
someguy is an unknown quantity at this point
yep go with a turbo. they are more tunable and will produce better gains then a supercharger. my friends come to me with these questions all the time. it just comes down to what you want. with a supercharger its less maintence and will give you a little boost in power. especially when you upgrade the pulley and stuff like that. turbos do require more maintence, but also can create more hp and torque. torque is something every honda guys needs...and something i cant get enough of. hopefully this might shed some light on your decision making process.
Old Oct 1, 2004
dragoon's Avatar
there's a lot of stuff in the way that would have to be relocated. we toyed with the idea over a year ago at a local shop using a centrifugal s/c out of a d16 kit.
Old Oct 1, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
superchargers are more geared towards a 6 or 8 cylinder engine because they already compress a ton and they need the low end power...you need the high end of a big turbo say 12-16 psi
but personally I would reccommend a swap for you...your d-series motor just simply doesn't displace enough to make any real power...make some all motor power with internals and overboring, then boost...
Old Oct 3, 2004
spyder2333's Avatar
EM2/DC5/LS1
Thanks kid hopefully I go with the right desision
Old Oct 4, 2004
iamboo's Avatar
Retired - SoCal FI Mod
locked due to the countless other "turbo or supercharger" threads
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
tomas6791
Sep 11, 2015 06:47 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
