Mex's Turbo Project: Complete!
Old Oct 3, 2004
  #31
C2i0v0i1C's Avatar
SuperMODrizd
the IAT cannot be in a positive pressurized pipe
u will get a BAROMETRIC PRESSURE CODE, i moved mine after i got the code and i havent gotten it since
Old Oct 3, 2004
  #32
civic01vtec's Avatar
for those of you that are triming the radiator fan shroud to fit the the piping all, all i gotta says is this...........
There are 5 bolts on the compressor housing, i forget what size. You loosen them up a little and the whole compressor housing will rotate.
As far as the intake pipe pinching the radiator hose, it will do that. I've been boosting for 6 months and have made some long trips with no problems of overheating. You can buy flexible hose..........but i haven't looked for it yet.
Old Oct 3, 2004
  #33
C2i0v0i1C's Avatar
SuperMODrizd
i used some d16 hoses on my aftermarket radiaotor
Old Oct 3, 2004
  #34
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
We have successfully driven the car, everything seems to be good! we're currently getting like 3 psi max (revved up to 5k) , but we're thinking it may just be because the MBC is at a low setting. otherwise we may be getting a leak at the T fitting in the vacuum lines (the factory line seemed to have a larger inner diameter than the T fitting's diameter)
the fuel pump is obnoxiously noisy, sometimes it sounds like an old packard bell trying to run Doom or something. any simple remedies for that?
other minor things.. the BOV is rattling against the hood slightly-- I guess we'll cut the coupling just a bit more. there's a rattle behind the glove box area in the engine, probably the air filter or the piping leading to it.
Old Oct 4, 2004
  #35
Mex's Avatar
Mex
I should also mention that my fuel pressure has always been steady at 50, even when the boost gauge is reading 3psi.. shouldn't that up it a little, or does the SF fuel system not kick in until a certain psi?;
Here's a pic of the wastegate/hallman MBC:
and a pic of where we tapped into the vacuum hose:
Old Oct 4, 2004
  #36
FuzzBeC00L's Avatar
Fuzzy Boy
Looks good man
Old Oct 4, 2004
  #37
civicskater's Avatar
Chicks dig my scent
awesome man, once you get the little quarks worked out turn that boost up!!
Old Oct 4, 2004
  #38
HyaBoosta's Avatar
yeah im dying to see some dyno numbers
Old Oct 4, 2004
  #39
jmjmotorsport's Avatar
jmjmotorsport is an unknown quantity at this point
looks good mex... hey, I'm in PW, and have been toying w/ the idea of boosting my civic.. I'd like to check out one in person when you get everything ironed out.
Old Oct 4, 2004
  #40
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
it should start going up after a few psi. 50 psi is base pressure, and thats good for 2-3 psi. if it doesnt, i will send you a new one out.
Old Oct 4, 2004
  #41
WhiteCastle's Avatar
thats customer support!!!! . you get a new tranny yet catalyst?
I want to come down see you run at the track sometime with your civic!
whats it now 12 secounds?
Old Oct 4, 2004
  #42
Catalyst's Avatar
i had to edit mine, because i just saw that he doesnt have the new one.
sorry.
Old Oct 4, 2004
  #43
ohh ya. Yourinmyworld kit rocks!! aka Johns. hes running rich though, its been like a year now ehs had it and still needs it tuned on the dyno....
thats his fualt though should get lazy *** to one
Old Oct 4, 2004
  #44
Catalyst's Avatar
lol.
Yes. I fixed my tranny. I am still leary of putting the slicks on my car, since that is what broke the tranny and my 6 puck.
But yea, 12's should be no problem.
Anyway, back on topic.
Mex, if it doesnt increase, send me a PM. Ill send you another system, and you can send that one back when you get it.
Old Oct 4, 2004
  #45
Mex's Avatar
Mex
thanks for the reply, it seems to be working now we're leaving it around 4psi for the time being. would you have any recommendation for a less noisy pump?
Old Oct 4, 2004
  #46
Catalyst's Avatar
Well, i have 2 options that i came up with for my car....
Option #1. You can purchase a pressure switch, drill and tap your bonett pipe, and set the pressure switch to come on a .5 psi. So the pump will only come on under boost.
Pressure switches run from $15-$50 depending on where you get them.
Option #2. You can purchase the black box piggyback for $265, which comes with a program and extra wire that control the fuel system. Only turns it on under boost. So when you are cruising or idling, the pump is not on. This ems is very similar to an emanage without the timing addon.
Old Oct 5, 2004
  #47
Mex's Avatar
Mex
Option 2 is tempting. Is this something that can be tuned using a laptop, gathering the data as you drive? do you have any more info about it?
I'm wondering how easy it would be to install/tune on my own. Dyno's are hard to come by around here.
Old Oct 5, 2004
  #48
Catalyst's Avatar
Well, you would need a wideband O2 sensor and a laptop to program it. I do almost all of my tuning on the road, and then just check it on the dyno. The ems can datalog some things, like boost vs RPM and then some external inputs that you can configure (but i have never used).
If you are interested, it is the Split Second programmable signal conditioner.
-HondaFTW-
Aug 30, 2015 10:38 AM
GritzNGravy
Aug 19, 2015 03:03 AM
Amulon
Aug 18, 2015 11:03 AM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
