Mex's Turbo Project: Complete!
Old Sep 30, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
edit: see final posts for results
Old Sep 30, 2004
VTECTypeR's Avatar
The sensor plugged into ur intake I believe goes right by the filter. But im not too sure on that.
Old Sep 30, 2004
civic01vtec's Avatar
congrats.....hope everything goes at planned (it won't )
yes, that is correct for the fuel. Your fuel system should be marked "In" and "Out"
as far as the IAT sensor...........SF does not provide a hole for it...........so u have to tie if off.
I am gonna do Madwheel's DIY for that
Old Sep 30, 2004
actually, looking at that pic now, that fuel system is not right.
The pump should be on the other side of the FMU. See that little aluminum piece that forms a "U"...........that is a bypass. If your pump breaks, then fuel will not get to your rail. The bypass will still allow fuel to flow through the fuel sytem to ur rail.
Old Sep 30, 2004
Titleist71's Avatar
The IAT needs to be used in the manner as if it were stock. If you do not hook it up your car will not run right, even tho it may seem to. It needs to be mounted somewhere near the throttle body. I used my throttle body elbow of the injen intake because it has a bung. Hope this helps
Old Sep 30, 2004
civicskater's Avatar
Chicks dig my scent
i just used the gromet piece off the intake, drilled a hole in my chargepipe and put that sucker in, no CEL or anything
Old Sep 30, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Mex, I'm not trying to offend you or anything but explain this to me....
A fully built block to run boost with a SF Fuel system?
Old Sep 30, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
if you don't have it made to work with the upper charge pipes it will cause that obnoxious Rev up and down problem that you here some older honda owners have when they are next to you, they aren't revving, the Temp sensor just doesn't see that the engine is hot already so it is constantly trying to warm it up....
Old Sep 30, 2004
gotti's Avatar
I just have mine dangling in the engine bay?
Old Sep 30, 2004
Mex's Avatar
Mex
That would be Supermex.
so basically, I can just drill a hole for the IAT before the throttle body? Seems simple enough.
Old Sep 30, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
I took my air temp sensor and threaded it. Then went to a hard ware store and found a hut the same as the threads and got it welded onto the pipe. Ill post pictures later.
Old Sep 30, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
You have a choice..
You can either drill a hole in a charge pipe and install it there.
or
You can tie it off. As long as the sensor is hooked up, the car will never know the difference. It only uses it to slightly modify the fuel trims according to temperature. Its just Honda trying to get the most fuel efficient vehicle.
Old Sep 30, 2004
opto_isolator's Avatar
Originally Posted by Catalyst
You have a choice..
or
Actually it effects timing more than fuel.....I would install it. When heat increases, timing decreases.....rather useful little device if you want to run boost.
Old Sep 30, 2004
Spider883's Avatar
9K Redline Owns U
hey mex.. i didnt know you were still on here... i hope your project finishes well and cant wait to see the finished product. good luck
Old Sep 30, 2004
i have mine turned off and when it is hot outside, i get a CEL
I am gonna thread the sensor and tap the charge pipe like madwheel did
Old Oct 1, 2004
Mex's Avatar
Mex
I went ahead and drilled a hole near the BOV for the IAT, then just used the grommet from my old intake.
Well, we accomplished a lot today, all we have left to do is attach the IC piping, replace the oil pan, run oil lines and run a few more wires in the engine bay.
We have run into a couple issues-- the main of which is there just isn't ANY room around the turbo to do anything. we had to take off the wastegate just to fit the turbo/manifold into place, then reattach it.
we had to stop for the night because it was getting dark, but at the time we were stumped about how to run the piping, because it's very crowded around the turbo. we were trying to attach the turbo to the intercooler, but we can't get the pipe to fit in the tiny space we have to work with. it's rubbing against the radiator fan and all kinds of hoses. I'm skeptical now if i even have a kit made for a 7th gen. Take a look at the pic... do I have all the [correct] pipes? Does the manifold look right?
Old Oct 1, 2004
Mex's Avatar
Mex
More pics:
Old Oct 1, 2004
MadWheel's Avatar
Premium Boosted Member
it will fit. You need to trim three of the black plastic supports for the passenger side fan. That fan is pretty much useless once you install the kit. Did you bang out or grind down the metal on the side where the intercooler pipes go into the engine bay area? That helped me a lot, and according to the DIY it's a must. Also, there's a lil bracket on the back of the batter that sticks out to hold some wires or whatnot, dremel that off and the upper charge pipe will sit much happier.
If you blow pipes off the couplers once in a while, spray the edges with some hair spray. No more probs after that.
Old Oct 1, 2004
Catalyst's Avatar
is the pipe off the bottom of the turbo rubbing? If so, the turbo may be clocked a degree or two off. It is normally a very tight fit. If it is impossible for that pipe to fit, then you may need to re-clock the compressor housing of the turbo.
If it is impossible to fit the pipe, the compressor will need to be clocked 1-3 degrees towards the block. This is accomplished by losening the bolts holding the housing on, then easily turning the housing. Make sure that when you tighten the bolts, you tighten them all down evenly, going in small increments.
Here is a diagram of where the pipes go. I hope this helps with the install.
This routing Starts with the TB at the top, to the intercooler, to the turbo, then to the filter.
Old Oct 1, 2004
MadWheel's Avatar
good post cat, nice to see ya on the boards
Old Oct 2, 2004
Mex's Avatar
Mex
Thanks for the info! We're back to work.
... and stopped just as quickly, damn rain. we won't have a chance to get back to work until sunday morning. another thing that's confusing us are the couplings.. we're not certain where each size should go. The coupling we have on the bonnet has some room for air to enter/escape through the sides (mainly because of the shape), but I don't think a smaller coupling would fit on it.
Old Oct 2, 2004
Mex's Avatar
Mex
somehow we got the piping to work. The ATF lines were causing an issue.
Old Oct 2, 2004
Chicks dig my scent
definately get rid of the black pieces over the fan, i think it'll clear up some room and make things a bit easier. Other than that looks really good, i also wouldnt put a smaller coupling over the bonnet, but as long as it is no major problem (boost leak) or anything like that you should be fine, good job man
Old Oct 2, 2004
Mex's Avatar
Mex
Here's an update with more pics.
We have a new problem. the intake pipe to the turbo is pinching the lower radiator hose pretty bad at the inlet (see pic below). the inner diameter is pinched to about half of what it should be. how did you SF turbo guys work around this?
Old Oct 2, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Nice to see the manifold already rusting....
Old Oct 3, 2004
MadWheel's Avatar
when i had my kit it pinched the hose a lil too, i just dealt with mine because it wasn't TOO severe.
Old Oct 3, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Is there a way to move the hole radiator assembly forward just for an inch?
Modifing the upper and lower brackets of the radiator?
Or change the fans to thiner FAL fans?
Old Oct 3, 2004
Titleist71's Avatar
the radiator hose thing happened to me Mex. I just wrapped the hose with electrical tape to prevent it from rubbing.
Old Oct 3, 2004
dragoon's Avatar
I didn't have a problem with the hose, but I did with the radiator fan. It should be ok to chop off 1 or 2 of those black plastic pieces without hurting much.
Old Oct 3, 2004
Mex's Avatar
Mex
we've got the oil pan mounted, now all we need to do is let it cure for awhile and I can start her up
