Emanage and FMU?????
Old Sep 17, 2004
HyaBoosta's Avatar
Im finishing up the little details on my turbo set up. I have RSX-S injectors,MSD inline pump,aeromotive digital fmu and VAFC. But as I recently learned, the vafc is going to throow off my timing so thats the last thing that I need at 10psi. So im switching over from the VAFC to an Emanage. My question is...Is my Digital FMU going to be useless in the fuel setup if the emanage is manipulating the injectors,fuel curve,and ignition? Or is it going to act as an expensive FPR?
Old Sep 17, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You don't need the FMU if you are using the e-Manage. Just go to Titan or SFP and get it tuned
Old Sep 18, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
So would he pull the in-line pump and be able to tune with the stock fuel pressure or would you wire the pump to a switched 12v source?
Old Sep 18, 2004
Your Parts Guy
If he needs more fuel then yes that would be a decent solution. If it was me I'd pull the OEM pump out and throw a Walbro 255lph pump in. If he isnt leaning out then there is no need for the inline pump.
Old Sep 18, 2004
HyaBoosta's Avatar
i think i'll drop in the msd pump just to be safe. then when I finish my motor build i'll go to the SLP return conversion.
Old Sep 19, 2004
HyaBoosta's Avatar
well i just got another opinion that says that i can use the fmu for a rough tune and use the emanage to fine tune for reliability. any other thoughts?
Old Sep 19, 2004
MadWheel's Avatar
Premium Boosted Member
I like SLP's idea of the Walbro 255 in-tank... A lot of people on the EVO boards swear by this pump so it should serve well in addition to your current setup.
Old Sep 19, 2004
TheSmuggler's Avatar
Alot of ppl on all boards swear by it. You go to the Zilvia (240sx) board and every single place that will do engine swaps uses it. You wont go wrong with the Walbro pump, like SLP said
Old Sep 19, 2004
HyaBoosta's Avatar
so would I be able to replace the pump in tank with the Walbro pump and not need an inline? I would have to remove the fuel filter for good too right? then need a FPR to tune the fuel as well?or would the emange do that? cause if thats the case it's just like doing the return conversion.
Old Sep 19, 2004
tfnaaf's Avatar
BLDNPSI Mod
You will need to convert over to return style system if you change the intank pump to the walbro i THINK! This is the route im going. I've got the pump just need the lines, regulator, and moddied fuel rail.
Old Sep 19, 2004
Your Parts Guy
You don't have to convert to return style but if you want to add more fuel you will. The in-tank FPR would be in the way.
Old Sep 19, 2004
civic01vtec's Avatar
right..........so basically yeah..........u will need to convert.
Old Sep 19, 2004
tfnaaf's Avatar
BLDNPSI Mod
^^^ i havent done my conversion yet, so i gathered that the intank FPR needs to be elimanated to install the walbro yes ?
Old Sep 19, 2004
Your Parts Guy
To take advantage of the Walbro, yes.
slowcivic
Engine Swaps
Jul 9, 2004 10:15 PM
REDchirp
Engine Swaps
Jul 6, 2004 04:22 PM
opto_isolator
Engine Swaps
Oct 8, 2003 07:49 PM
Rodawg
Aug 24, 2003 11:42 AM
SODJAZERO
Engine Swaps
Apr 8, 2003 08:16 AM
