Need Some Advice
Old Sep 6, 2004
ImportRacer2123's Avatar
K20 Member
Need Some Advice
OK i went out tonight and i was itching for a race well little did I know my car would hate me. So here is my story of my problems anyone who thinks they know what could be wrong please chime in at any time.
my car at 45-55% throttle would go to 7psi but WOT it would only go to 5psi. When it would go to 5 PSI it would pull til 4000RPM's and then die til 5100 and pick back up and then shift for me at 6400rpms (yes i have an auto). I COULD NOT PULL on a Stock EG hatch gutted... When I looked at my Air Fuel Gauge it showed it going lean at the 4000RPM range and then back to rich at 5100. IS there a way to Adjust my Fuel Pressure with the SF system? Or Should i go return conversion and E-manage. I know 1 thing is for sure. I am getting e-manage and dyno tuning it. I am going to check my plugs tomorrow and do a compression test as well. I will post my results tomorrow.
Old Sep 6, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
sounds like you are having fuel probs...i would check that out first...check that stupid fuel pump too,to make sure that it is working
Old Sep 6, 2004
K20 Member
i have a Holley Electric Fuel Pump instead of the carquest one because the one that came on my fuel system was already burned out. I know for a fact its working its loud as hell.
Old Sep 6, 2004
civicskater's Avatar
Chicks dig my scent
did you ever get your vafc II tuned? rather than setting all the fuel maps at 0? I definately think you have fuel delivery problems....if money/times not an issue id do return and emanage
Old Sep 6, 2004
K20 Member
yeah thats what i am thinking...
Old Sep 6, 2004
K20 Member
We Did a compression test on it today and it was 150 all the way accross. Checked the Spark plugs and they are doin ok need to be changed. Anyone got the Part number for the Denso ones that I need?
Old Sep 6, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
How many miles are on your ride?
my compression test came out at 205 per cylinder at 24,000 miles.
Old Sep 7, 2004
K20 Member
i have an ex and i have 38,000 miles
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
