My 01 civic with a K20A blew and there is a serious probs.
Old Sep 7, 2004
  #31
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
Originally Posted by Anotherslo1
Maybe your piston was bad to begin with, and the turbo was the "straw that broke the camels back". You don't have to drop the engine to fix the piston. Since you are not taking out your transmission the engine will come out the top. As for the 11:1 compression, that is what I run, it is said the k20a2 is built well enough to handle up to 11 psi with stock internals. There are many members on Clubrsx.com that run 11:1 compression and turbo'd. Find out for sure it's just the piston and replace or pay to replace it. Not sure on estimate, but piston rings and pistons get blown all the time, replacing it shouldn't be expensive. The expensive part is buying the piston itself, and if you decide to go lower compression, to replace all 4 will be costly.
very true weakest part of any k20 is the rod and pistons. id invest in some rod and pistons if ure block and head isnt trashed.
Old Sep 7, 2004
  #32
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
why did they change the gapping on the plugs??
Old Sep 7, 2004
  #33
joedc5's Avatar
joedc5 is an unknown quantity at this point
Originally Posted by Prod
You have no clue what you're talking about. Please do not try to misinform this person.
As for you joe, When you said you heard it crackling.... I seriously cringed.. That gave me the biggest cold chill. Detonation I'd post up and find someone locally on ClubRSX, or a local board and find someone that knows how to tune with a k-pro... The people who tuned yours obviously do not have the slightest clue. I'd hate to have to see you go through this again.
Also, what octane gas are you running? With 7 lbs, and 11.5:1 comp........ shouldn't he be running 100+? This may be why you're detonating?
I have run always 93 octance and nothing ever less
Old Sep 7, 2004
  #34
joedc5's Avatar
I don't know, the gapping was for the rsx type-s . I put in RSX type-s NGK plugs they should be factory gapped
Old Sep 7, 2004
  #35
Hawk's Avatar
You boost, I-VTEC
This may be the problem? I'm no expert, but boost + 11.5 comp + 93 octane = a no no.....
its not necessarily a no no, it just won't run at optimum performance.
but on the other hand 7psi + 11.5 to 1 compresion = no no.
Old Sep 7, 2004
  #36
MadWheel's Avatar
Premium Boosted Member
Yeah I man I know the damage has been done, but why'd you buy the A motor if you were going to boost it? Too late now, but I'd buy some Arias pistons, and if you want more boost, get some upgraded forged rods and sleeve the block. You can make some serious power then.
Old Sep 7, 2004
  #37
FSRbikr98's Avatar
FSRbikr98 is an unknown quantity at this point
As someone said in an earlier post, RPM racing located in Huntington Station, NY is pretty sick. i live around the block and went down to the shop w/ my friend to see if they could figure out whats wrong with his AWE clutch(Audi a4 1.8t). They were awesome guys, the whole team came out to bs about what could be wrong, then they brought us into the shop to see one of their supercharged m5's. The car was ridiculous and they seemed to take pride in their work. So yea take it down there, i'm sure they will be able to help you out.
Old Sep 7, 2004
  #38
Jodster's Avatar
Post Whore General
Running Boost on a 11.5:1 compression is ok, its just going to need a lot of tuning. And the K-pro is great for that. What did you gap the spark plugs too? If I remember correctly, they have to be gapped to .32 for boost. I'm not 100% sure though. You can look it up on clubrsx though.
Old Sep 7, 2004
  #39
dezod's Avatar
7thgen Power Maker
Actually, there stock rods are pretty strong. It took 21 PSI to snap a rod in half. I seen it in person. Not mention, whoever mentioned the K20 doesn't like boost, your WAY off base.
The K20 eats boost and asks for more. 7 PSI on the Cybernation kit runs 275 WHP & a 12.5 1/4 mile. Ummmm. I think it respons quite well.
Old Sep 7, 2004
  #40
Titleist71's Avatar
Oh, and speaking about the above person I quoted............ that's why a member of these boards runs 27 lbs DAILY....... and 35 at the track? But k20's don't like boost.. You have no clue what you're talking about.
Who? Prove it. See I make a simple statement, a simple generalization and people like you try to sound cool and "better than" others by telling me that "I have no clue" Are YOU a turbo guru? Are you a Engine Management guru? NO! Neither am I but I am trying to throw out ideas to help. Why don't you have a seat. Nobody stands up to your snod comments. Well guess what you just ran into one of the most stubborn, hardasses in the world. You Prod are always making smartass comments and ya know what I get tired of it sometimes. It's not always funny. Frankly I think its childish. No **** Prod, 11.5:1 with 7psi and tuning would be safe...you think I didn't know that? How about lowering it to 9.5:1 @7psi and tuning make a lil more sense? More safe? Do I still sound like a "noob"? Huh? Any idiot knows that a high compression ratio and forced induction is not good. Why do they lower it then....for the hell of it? ***** and giggles? 1. To run higher boost,2. To keep it safe from blowing up. At 11.5:1 I would go no higher than 5psi and 94 octane. But I'm just a "noob" so I'll shut up because Prod said I should...I mean after all he is the uber coolest guy here....I apologize in advance if I offended anyone else. I deal/teach smartass kids at school all day...and it just hit a nerve that caused me to get mad and vent. I'm usually very quiet here.....I try not to be the center of attention...ahemm.....well I'm tired lol. I 'm gonna do some more research on this topic. Sorry Joe for smackin your thread around!.
Old Sep 7, 2004
  #41
Titleist71's Avatar
From a member of ClubRSX..."Max boost is really depends on your setup and tunning. 5 pounds should be a walk in the park. Change your oil regularly and it your car maintained. High compression boost is not recomended if you want to boost more and have a reliable car you need to lower compression buy installing lower comp pistons. 9:1"
Old Sep 7, 2004
  #42
Titleist71's Avatar
"most Honda motors tuned properly like an 11-11.5:1 static compression ratio for a safe but powerful amount of heat on premium octane gasoline. You can often go as high as 12.5:1 on a really well built motor with pump gas, but this takes $$ and a great understanding of the engine you're building."...directly from Compression 101: on www.speedupgrade.com
Old Sep 7, 2004
  #43
doubledeuce2k2's Avatar
the first part is referring to a daily driver kind of setup. highly doubt thats what he's going for, but remotely possible. with higher compression you can glean more power, specifically torque. lower comp pistons are reccommended to keep it reliable (read: less torque and less heat) not make a more powerful car.
the second part is refering to n/a pretty much. so it doesn't apply.
Old Sep 8, 2004
  #44
Havok2k1's Avatar
Wicked Pissah Admin
Enough Prod and Titleist.........
Old Sep 8, 2004
  #45
Team Hi Voltage's Avatar
Team Hi Voltage is an unknown quantity at this point
Old Sep 8, 2004
  #46
Titleist71's Avatar
no problem Havok...just don't appreciate being pushed around.
Old Sep 8, 2004
  #47
joedc5's Avatar
Thanks for the info, no worries about throwing the thread around. Reguardless it's the shops fault. I think they forgot to put coolant in the motor. There was none in the radiator after the trouble suddenly happened.
Old Sep 8, 2004
  #48
Hawk's Avatar
You boost, I-VTEC
If they forgot to put coolant in the car it would have been dead in about 20 minutes. Your headgasket more than likely blew.
Old Sep 8, 2004
  #49
HyaBoosta's Avatar
Is this the Type R K20? I
Old Sep 8, 2004
  #50
MadWheel's Avatar
Yeah it WAS.
The shop's replacing all of the damage correct? It better be perfect.
Old Sep 8, 2004
  #51
HyaBoosta's Avatar
Thats what happens when you take a high compression engine, add a turbo and have a crappy shop tune it for you. With compression that high you have to be right on point with the tunning.I hope they at least had a dyno.
Old Sep 10, 2004
  #52
joedc5's Avatar
Well, guys great news. I brought it to the shop and the piston ring is blown. Well now I am having them sleeve the block,lower compression forged pistions, eagle rods, port and polish, fuel system, boost controller and I should be pushing close to 450whp. Yippy! It's gonna cost me $4000 but I got a few months to come up with the cash. Prolly good for christmas! Just keepin you on the update and I will post pics of the work! Thanks again you guys for all your help and suggestions!
Old Sep 10, 2004
  #53
Titleist71's Avatar
No prob...good look on lowering the compression and going forged.
Old Sep 10, 2004
  #54
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
W00t W00t!
Old Sep 10, 2004
  #55
gotti's Avatar
wow...props
Old Sep 11, 2004
  #56
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
man u have WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAY 2 much money....do u own a house yet? b/c u will be riding in a DOWN PAYMENT of one...how old are u? sorry man but this is just CRAZY $$...not hating b/c I would prolly do the same if I had it lol...
Old Sep 11, 2004
  #57
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
dam i hope this does not happen to me
Old Feb 23, 2005
  #58
2K1Civic17"Gabe's Avatar
I remember when this thread started. It was sort of hilarious. he was all excited about getting a turbo for his K20, and didnt want to listen about the compression. He boosted and blew, at least he sold it on Ebay for a good amount
Old Feb 23, 2005
  #59
cambo's Avatar
I wish I was asian
if you remembered it, then why did you revive it?
Old Feb 23, 2005
  #60
I done felt like it. I was reading through and felt like posting something.
miatabro
Jul 17, 2015 12:12 PM
chgofirefighter
Apr 18, 2015 08:08 PM
mugenca
Apr 16, 2015 12:15 AM
smmahan
Apr 15, 2015 08:17 PM
Grey
Nov 9, 2001 09:41 PM
