safc issue
Old Feb 21, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Question safc issue
Ok folks im gonna try to explain this to the best of my ablity.
I just installed the return fuel line, type s ints, fpr and safc. Now here is the problem i am running into. When at WOT or HI throttle when ever i hit 4600 4500rpm the engine cuts out and the car suputters like it wants to die out. The a/f gauge shows RED for lean, normaly it shows BLUE for rich. The settings on the safc show for that rpm range are 30% (rich) and up. To try to fix this problem i reset the safc and reset all the settings back. For the first few pulls it was ok, then i retested it out later and the problem came back. Its like the fuel custs off at between 4 and 5 rpm. Do you guys know what the problem could possibly be?
Old Feb 21, 2005
Michalo187's Avatar
Abortion Survivor
Take it to a mechanic dude that sounds dangerous. You could hurt your engine running lean.
Old Feb 21, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Put a real wideband on there and be sure of what it's doing. If you can wait until tomorrow night, I can help you with my wideband (working until then), otherwise don't go into boost until you use a wideband. I don't want to have to help you swap motors out...
Old Feb 21, 2005
SODJAZERO's Avatar
Thanks for the help burnerex, but i think i have a controller problem, because i can drive in HI throttle but not be in boost, and it will do the same, i will show you if you have the time to help, i get off at 4pm so i call you a little after that if thats ok with you. . . .
Old Feb 21, 2005
First to spool
I'm off work at 6, give me a call on my cell phone and we can take a look at it.
Old Feb 22, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
Did you ever figure out what the problem was?
Old Feb 23, 2005
bakablo's Avatar
bakablo is an unknown quantity at this point
i had then when I was running my turbo with no fuel...
your running lean...... take it to a dyno or get it tuned
Old Feb 23, 2005
SODJAZERO's Avatar
For everyones info this has been dyno tuned. This problem started after i left the dyno, so STOP telling me that I need to put it on a dyno because it does not take a rocket scientest to see that my car has fuel problems.
I also called apexi, those techs are not too bright.
wh3nw0rdsesc4pe
Mar 23, 2003 09:57 AM
icebergslim
Apr 13, 2002 04:36 PM
civichx81
17
Apr 6, 2002 06:43 PM
PiCASSO
Mar 10, 2002 01:34 PM
Booohahaha
Mar 3, 2002 09:53 PM
