Boosting and check engine light update
Well still dont have a solution but the honda ecu is throwing a vtec code ,as well as my greddy e-manage. The car still wants to cut out around 4 grand
anybody have any ideas whats going on and how to fix.
thanks
thanks
thanks
thanks
I got my car back and it ran great Tim did an exellent job,three days later my check engine light came on and started cutting out at 4 grand.And yes i have the missing link sorry but im at work right now and cant answer as fast as i would like to.
Jeez read the damn sticky dezod and I made!!!
Follow that thread and your car will work fine. Missing link is for a barometric error, nothing to do with VTEC. It's the settings on your e-manage, and your wiring.
In case opto sees this... Our ignition voltage is 12vdc not 5. Found that in my $100 service manual.
yeah sounds like you are trying to use the vtec controller with the emanage. just disconnect it from the vtec wires and put them back to stock. I got my ign. voltage at 5v and its worked fine for over a year. ah well lol
BTW - I don't understand everyone's talk about using the Emanage and missing link. The emanage has a feature called "boost limiter cut" or something, which limits the MAP voltage the ECU sees - essentially an electronic boost clamp (wheras the missing link is mechanical in nature). You don't need it if the emanage is set up properly.
Originally Posted by opto_isolator
Yes - your right, the coil packs do discharge at 12 volts. However, the pulses which the ECU sends to the coil packs are only around 5 volts (similar to a relay - also known as a transistor). If you look at page 11-18 in the helm manual - you'll see the denotation of "E," connected to each coil pack. This references a direct connection to the fuse box (which I believe is a 15A fuse). If you set the logic in the emanage to 12 volts you might damage something....but, by all means be my guest - its your car.
. Boost on... Thread
Xuhme
21
Aug 7, 2023 03:40 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
