problems while boosting
Old Aug 13, 2004
  #31
Havok2k1's Avatar
Wicked Pissah Admin
Is it just me or does that sound like overkill on the fuel department........?
Old Aug 13, 2004
  #32
civic01vtec's Avatar
naw, u need a both a safc and e-mange to control fuel. It gives you another 10whp.
Old Aug 13, 2004
  #33
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
so is it really overkill or is it a good thing?
Old Aug 14, 2004
  #34
major overkill
Old Aug 14, 2004
  #35
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
yep once you tune with the emanage leave it there. If you have a safc to play with you are changing all your fuel maps. Unless you are using it for the guages that it has your kinda waisting your time.
Old Aug 14, 2004
  #36
but then again this is all prep for a turbo... once i put in the turbo is it still overkill.. i was always told u should do the fuel before u boost cause u gonna run lean... or is the safc2 (or vafc2) all i need to properly boost
Old Aug 15, 2004
  #37
Well, if you are gonna use the SAFC or E-mange, then go for the Emange. You can do so much more and it cost the same.
Old Aug 15, 2004
  #38
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
xproductionz--your gonna wanna buy a new clutch. my turbo destroyed my OEM clutch in a matter of a week. its not a bad thing though
Old Aug 15, 2004
  #39
yeah, u will need a clutch
Luckily, i've been boosting at 9psi for 4 months on stock clutch and i have 45,000 miles on my car.
Old Aug 15, 2004
  #40
actually, my friction plate was fine, but my pressure plate was roasted
Old Aug 15, 2004
  #41
mine probably grabbed for ......4 hours, then it was skippin like mad for a week till i got it changed--it couldnt take it, i was only runnin 5lbs
Old Aug 15, 2004
  #42
not worried bout the clutch cause i already got that covered.. its just a matter of getting what for turbo prep (not including clutch or anything transmission)... but like i was saying will getting both an emanage and safc be bad or just one of em... nobodys really saying the right path here on the fuel... i mean fueal rail and injectors and fuel pump and emanage will do or what or should i just use emanage??
Old Aug 15, 2004
  #43
get the emanage. you can ALOT more with it and not much more money.
Old Aug 15, 2004
  #44
emanage, pump, injectors
Old Aug 15, 2004
  #45
If you upgrade you intake pump, u will need to get a fpr and do a return fuel conversion.
Do Not get both the SAFC and E-manage. Get one or the other......u will be better off with the E-manage.
With the E-manage u can upgrade your injectors and/or get a vortech fmu with inline fuel pump.
Old Aug 15, 2004
  #46
when are you boosting xpro? ive only been boosted for a coupla weeks
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
