problems while boosting
Old Aug 10, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
ive recently installed my pieced together kit. if i run low boost (3-5) it runs great. if i go to about 7 lbs, it does good till about 5000 rpms, then the car chugs a little bit. i dont think its detonation, cause it doesnt sound like it and im pretty sure my motor would be dead by now if it was. does that sound like detonatino to you guys?
Old Aug 10, 2004
the reason im worried bout detonation is because i made my own fuel system with FMU and inline pump...so who knows if it works. also, getting cam gear and installing today.
Old Aug 10, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
What are you using to hide boost from the map sensor?
Old Aug 10, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
get your car dyno'ed with the a/f ratio... you may be running lean
Old Aug 10, 2004
just check valves
Old Aug 10, 2004
will retarding timing with the cam gear reduce possibility of detonation?
Old Aug 10, 2004
anyway, im off to the nopi store to get that cam gear...ill chekc back later
Old Aug 10, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
chances are that if you're only running 7 psi you are not detonating ... unless you're running 87 octane, then maybe. Use premium octane ... then you shouldn't have that much of a problem ...
I think retarding it will reduce detonation ...
like I said .. get it dyno'ed! ;P
Old Aug 10, 2004
Your Parts Guy
Originally Posted by maiden4ever
just check valves
Get a missing link.
Old Aug 10, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Sounds like you are running lean, my car did somthing like that when it was getting tuned. I have the mf 2 tho.
Old Aug 10, 2004
SODJAZERO's Avatar
Do you have an a/f gauge?
Old Aug 10, 2004
got the gear! no i do not have a/f. and your right--i do need to have it dyno tuned. problem is, im going back to valdosta for school in a couple days ...dont hvae time
Old Aug 10, 2004
SODJAZERO's Avatar
I would buy a autometer a/f gauge. Turn it back down to 5 psi. Untill you can get it on a real dyno and wideband.
Old Aug 10, 2004
...narrow band a/f is useless...
Old Aug 10, 2004
Your Parts Guy
AEM UEGO Wideband Gauge
Old Aug 10, 2004
HyaBoosta's Avatar
redchirp just blew his motor because he didn;t take the time to get a fuel system and rushed into it. and it seems you put your boost on in a hurry and didn;t cover all the details either. IMO alot of people are getting excited about boosting their cars and just put on the the main components and rush it cause they don;t have the money right then to get everything and say"just run low boost till i get it" or boost their daily drivers and don;t get them tuned because they have to go to work. when i finish my kit i will be running 1 psi from my house after the install straight to SFP to get it tuned. and i know it sucks i have to wait to get enough money to buy every part, and wait to get it tuned before I drive it, but This is one of those things that needs to be done right the first time and thripple checked for every detail.I know alot of people on this site have installed there own boost and it sounds easy like a weekend job but i know Im gonna have to go without my car for about a week and a 1/2 to 2 weeks so i can make it a clean install.Just my .02
Old Aug 10, 2004
....its ok man...its ok
Old Aug 10, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Cam timing and ignition timing are two different things guys. Besides cam timing is best left stock with forced induction ("straight up" is the term used buy engine builders) read about forced induction from anywhere you can. Info is key. Know your motor inside and out before you go messing with it. F/I is very unforgiving.
Old Aug 10, 2004
yeah ...well im not buying a standalone just for timing
Old Aug 10, 2004
civic01vtec's Avatar
what for checkvalve are u using ?
Like Dober said.........the Synapse ML will most likey solve ur problem
Old Aug 10, 2004
2001rolla's Avatar
2001rolla should not be trusted
If you don't mind paying more than $400 for a guage...
Go Here: http://www.innovatemotorsports.com/lm1.php
For $350 you can get a fully digital air/fuel ratio meter that's ten times more acurate than the AEM unit and aloows for up to five more inputs (RPM, MAP, MAF,TPS, etc)... Data gathered by the unit can be downloaded to a computer to be viewed, analyzed, and processed.
This thing allows you to tune your car on the fly without having to take it to a dyno.
Old Aug 10, 2004
02fpcivic's Avatar
"yeah ...well im not buying a standalone just for timing"
e-manage has so many options other than fuel and timing. Its not much more than a VAFC or SAFC. Its not a standalone. with the harnesses and support tool you can prolly get it all for less than 450 if you shop. Plus you'll get more reliable horsepower, whats not to like. Get it for your b-day or x-mas or something lol. I promise you will love it.
Old Aug 10, 2004
Streetlevelperformance is offering the E-mange for $278 shipped and the support tool is $100.
http://www.7thgencivic.com/forums/sh...2&page=1&pp=15
Old Aug 10, 2004
02fpcivic's Avatar
BTW when I turned my ignition timing too far up (n/a) with the emanage it did the same thing you are describing. It stumbled and skipped on the top end. Our knock sensors freak out everything when you detonate. That may or may not be it IDK for sure.
Old Aug 13, 2004
that was it...retarded cam timing 3 degrees, runs like a champ
Old Aug 13, 2004
good deal........how much boost u running ?
Old Aug 13, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
glad to hear your problem is fixed
Old Aug 13, 2004
Havok2k1's Avatar
Wicked Pissah Admin
I'm glad it's fixed, but changing cam timing only changes the powerband.... It doesn't effect ignition timing... Sounds like it's masking something else....
Old Aug 13, 2004
maybe changing power band takes stress off high rpms or something? not sure.
Old Aug 13, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well.. imma be ordering my turbo setup by the end of this month.. but before i do that imma be doing some pre turbo parts installation.. im installing a safc2, e-manage, TB ported, cam gears, fuel pump, autometer c2 boost guage and a/f meter, greddy boost controller, rsx injectors and those fuel rails i read about in a different thread.. anything else i should be getting before the turbo installation???
