Case breather What are you using.
Old Aug 11, 2004
  #31
MadWheel's Avatar
Premium Boosted Member
Moroso Breather on Dezod's Site
Greddy's Oil Catch tank on Dezod's site - use this if you want to rout the other end to your intake pipe
Old Aug 11, 2004
  #32
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
a catch can is way better and more efficient than just puttin a breather on from pep boys or autozone.
Old Aug 12, 2004
  #33
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
technically you should use the catch can for the PCV lines and run that to the pre-turbo intake (unhook the line from the intake manifold and plug it), but the breather will pretty much do the same thing of removing pressure from the crankcase.
the valve cover breather should be routed to the pre-turbo intake, so you have air entering through the valve cover breather, and the vacuum drawing air out through the PCV end.
that's my plan, anyway.
Old Aug 13, 2004
  #34
cdmx's Avatar
I didn't pass emmissions with that lil damn filter
JetsterDajet
52
May 8, 2016 12:11 AM
haloway13
Nov 6, 2015 10:43 AM
260000milesgoal
Sep 25, 2015 07:41 PM
siliconvalley
Sep 15, 2015 09:48 PM
bashea
Sep 15, 2015 04:59 AM
