E-01 Help..........
Old Jul 29, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
E-01 Help..........
Anyone know where the presure sensor on the E-01 Boost controller goes conected to??
Cuz on the diagram it says to the fuel pressure regulator and to the intake manifold........
thanks........
Old Aug 7, 2004
when setting boost, let say i whant 6 psi what values should i select for GAIN.......
This is what the manual says for GAIN
This feature is used to stabilize the boost by changing the control valve´s duty cycle. the larger the value the faster the response will be and the lower it is, the response wll be slower. If the value is set too high, the boost will over shot (boost spike). Select this mode and input the desired solenoid duty cycle...
but i dont understand what it really does, or how should i set, it, i has values from 0 to 99
EM2typeflex
Mar 2, 2006 03:44 PM
03-Acura-1.7-EL
Engine Swaps
Jun 16, 2005 12:44 AM
Hwoody77
Engine Swaps
Mar 23, 2005 06:34 AM
Ahtasham
Engine Swaps
Mar 2, 2004 11:01 AM
