So I picked up a Profec E-01 and a spare E-Manage....
Old Mar 20, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, just as the title says, I picked up a spare E-Manage and Profec E-01 to put on my current E-Manage. Now, it came with a pressure sensor for the E-Manage, and I didn't really understand it's use, because the Profec E-01 comes with one...so what's this used for?
It also came with the second harness for E-manage, but it only has two wires on the harness a Blue/White and a Blue/Black....mine on the other ahnd had a whole bunch....anyobne know why this only has two?
Also, the Profec E-01 the voltage clamp, is that of any use for our cars? Maybe a Rev-Limiter? Or maybe a higher redline?
Thanks guys!
Old Mar 20, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
don't mean to jack your thread or anything but is there really a difference in the Profec E-01 and E-mange. For some reason I've been getting the impression the the Profec E-01 is just a emanage with the lcd screen. is that true?? or do u need to actually have the emange unit if u get the E-01??
Old Mar 20, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
The Greddy E-01 is an Emanage Controller and Boost Controller all in one. If you have the E-01 there is no need for the support tool to connect your emanage to a laptop to be controlled.
Old Mar 20, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Thanks guys!
Well you bought the pressure sensor for the e-manage but since the E-01 has one, u have no use for it now, you can just sell it-...
Old Mar 20, 2005
Hwoody77's Avatar
So, I can sell the extra pressure sensor? Anyone?
Old Mar 20, 2005
if yor e-01 already has a boost sensor, you dont have a need for the extra one that foes to the e-manage
Old Mar 21, 2005
Chris3k2's Avatar
so basically if I get the Profec E-01, then I won't have to get the emanage??? is that correct? and if so, will I need any of the extra harnesses or will the E-01 provide everything needed or be the same as getting an Emanage w/ all the harnesses??
Old Mar 21, 2005
No an E-01 is not an E-manage, it is just a boost controller, but if you hook it up to an E-manage you can control it with the E-01, also you would still need the main harness form the E-Manage and the Ingnition and Injector harnesses, you not need the pressure sensor or the sensor harness or the Support tool for the E-manage if you hook the E-01 and E-manage together
Old Mar 23, 2005
Hwoody77's Avatar
Anyone else wanna help out?
ken4444
Sep 30, 2015 07:37 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
Luluharp
Sep 27, 2015 11:56 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
