SLP return conversion test fitment complete
Old Jul 18, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
Well guys, Jeff from Streetlevelperformance and i finally got together to complete and install out Return Conversion...here is a couple pics....more to come
ID:	33185   Click image for larger version
Old Jul 18, 2004
ImportRacer2123's Avatar
K20 Member
Sweet Looks Damn Good..
Old Jul 18, 2004
abmerop18's Avatar
Jam out with your clam out.
looks great. how much does this kit cost?
Old Jul 18, 2004
jwcardy's Avatar
I will let jeff handle those ?'s.....we have talked about it, but nothing definate yet....
Old Jul 18, 2004
civic01vtec's Avatar
that looks sweet Wes..........can't wait for the DIY.
I think i am gonna convert to a return fuel set-up next yr......i don't want a FMU anymore. And i will definitely buying the set-up from Jeff at Streetlevel.
Old Jul 18, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
nice
Old Jul 18, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
ahhh sweet...ive been waiting for this for a while now! How hard is the installation of the kit? Something that someone relatively new to fuel systems would be able to do? Also what else would be needed in order to tune it? Or does the fuel pressure increase with boost levels? I guess what i should ask is if it includes a boost referencing pump or FMU. Fuel stuff confuses me.
Old Jul 18, 2004
you will need some type of piggyback and get it dyno tuned
Old Jul 18, 2004
abmerop18's Avatar
if you can get it to me for arouns 350-400, i will buy it, otherwise my shop already said they can do it for around that price
Old Jul 18, 2004
^^ahh i see. What are the options for a piggyback system? Ive heard the e-manage is a pain in the *** to wire up, and doesnt like our ecu very much. I also read that the missing link disrupts the code.
Any expected release date for the return kit?
Old Jul 18, 2004
^^^ a safc is nice
Old Jul 18, 2004
jwcardy's Avatar
...you have to understand, we didnt spare any cost on this...we used only the best parts...i would double check with you shop and see what they are using...
Old Jul 18, 2004
indeed...........all steel braided lines...YUM !!!!
Old Jul 18, 2004
jwcardy's Avatar
we are just waiting on the fuel rails to be finished,
Old Jul 18, 2004
Civic01vtec: but doenst the SAFC screw with ignition timing? So its detrimental to boosted motors. I guess a cam gear could be used too reverse the effects maybe?
Alright sounds good. I will forshure be in line to get a kit, so I can do my fuel set-up right the first time! Good job guys!
Old Jul 18, 2004
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
Keep us updated
Old Jul 19, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
The conversion kits will be ready to go soon. As Wes stated, everything went very well with the install. We took pictures every step of the way and plan on offering extremely detailed instructions with the kit.
Pricing will be dependent on the fuel lines you choose. The base kit will include standard fuel lines and the upgraded kit will include braided lines. The lines will be precut to exact measurements and will come with all fittings in place. All you'll have to do is screw them on and tighten them down.
It was mentioned above that this can be done for $350-$400. That was probably a labor quote and not an actual parts quote. We are including the best parts money can buy in these kits. We are not going to sell you carquest fuel pumps that burn out over time. Here's a list of the brand names that will be included:
Walbro
Aeromotive (boost referencing)
Earls
B&M
You also have to remember that we are taking ALL of the guess work out of this for you. We are making it as much of a bolt-on as we possibly can. We'll release more information very soon as we are monitoring the kit over the next week or two.
Old Jul 19, 2004
^^sounds good. Im sure everyone will be satisfied once they realise it comes with everything to do the conversion. Keep us updated.
Old Jul 19, 2004
orso's Avatar
orso is an unknown quantity at this point
this is interesting. maybe i should look into this. yes i think i will. good job fella's. keep is updated. thanks
Old Jul 19, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
can someone explain to me what a return fuel system does?
Old Jul 19, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
^^^ Here you go:
From: http://home.earthlink.net/~micfly/returnless.htm
Most electronic fuel injection systems, including TBI and EFI, use a return fuel system. What this means is fuel is pumped from the tank to the injectors on through a pressure regulator with any excess going back to the tank through a return fuel line. This keeps the fuel system at a constant pressure for proper fuel atomization. Return Fuel Systems are easy to manipulate fuel pressure with the addition of an FMU (Fuel Management Unit). Basically, the FMU is an adjustable fuel regulator controlled by a vacuum boost reference. Under a supercharged boost situation the FMU will "pinch" the return line (increase fuel pressure) forcing more fuel out the injectors.
Check out the link for more dertailed information / reading.
Old Jul 19, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, thanks~!
Old Jul 19, 2004
abmerop18's Avatar
Pricing will be dependant on the fuel lines you choose. The base kit will include standard fuel lines and the upgraded kit will include braided lines. The lines will be precut to exact measurements and will come with all fittings in place. All you'll have to do is screw them on and tighten them down.
Walbro
Earls
B&M
sounds good to me. i will defeniatly look into purchasing it from you when the right time comes.
Old Jul 19, 2004
AlpineCivic's Avatar
Damn if it works as good as it looks I will buy a kit no matter what the price. Keep the good work guys.
Old Jul 19, 2004
HyaBoosta's Avatar
got any pics of the fuel rail in the conversion?
Old Jul 19, 2004
Your Parts Guy
Wes posted some previously. It showed the modified rail with the weld bung that the kit will include.
Old Jul 19, 2004
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
can i just buy the modified fuel rail? or i have to buy the whole thing...
Old Jul 19, 2004
Your Parts Guy
It depends on how many fuel rails we can source. They are the hardest piece of the kit to come by so as of right now we won't be selling them individually. We are considering offering some money back if you send your unmodified fuel rail to us.
Old Jul 19, 2004
Green Civic's Avatar
^ Thats a good idea.
Wes- Looks good. Hope to see it turn out good in the end. I want to see your setup at the meet. What are you using to monitor the return setup wes? (Maybe I can get my ride at the meet if the turbo is on)
Old Jul 19, 2004
hey Jeff............what parts u using from Earl ??
