Understanding E-Manage Maps & Tuning
Old Jul 2, 2004
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I am trying to fully understand how to start tuning this E-manage system using the Greddy Pressure Sensor.
If anyone had information or maps to share please post it here.
Also info on how these maps are properly read would help too.
-Additional Injection Map
-Airflow Adjustment Map
-Anti Engine Stall Settings
- Boost Limiter Cut Setting
-Ignition Timing Adjustment Map
Name:	E-Manage Additional Injection Map.jpg
ID:	32119   Click image for larger version
Name:	E-Manage Airflow Adjustment Map.jpg
ID:	32120   Click image for larger version
Name:	E-Manage Anti Engine Stall Settings.jpg
ID:	32121   Click image for larger version
Name:	E-Manage Boost Limiter Cut Setting.jpg
ID:	32122   Click image for larger version
Name:	E-Manage Ignition Timing Adjustment Map.jpg
Old Jul 2, 2004
More E-Manage Pics
-Main Unit Setting Information (for EX - Vtec)
-Parameter Setting
-Sub Injector Map - Injector Duration
-Sub Injector Map - Injector Duty Cycle
-VTEC Setting
Name:	E-Manage Main Unit Setting Information.jpg
ID:	32125   Click image for larger version
Name:	E-Manage Parameter Setting.jpg
ID:	32126   Click image for larger version
Name:	E-Manage Sub Injector Map - Injector Duration.jpg
ID:	32127   Click image for larger version
Name:	E-Manage Sub Injector Map - Injector Duty Cycle.jpg
ID:	32128   Click image for larger version
Name:	E-Manage VTEC Setting.jpg
Old Jul 2, 2004
And the E-Manage Maps Help File.
It also has a real time data analysis feature, I tried this a bit with my laptop on the passenger seat, works great. No pics though.
Name:	E-Manage Maps Help File.jpg
ID:	32130   Click image for larger version
Name:	E-Manage Data Analysis Graph.jpg
ID:	32131   Click image for larger version
Name:	E-Manage Data Analysis Input Data Setup.jpg
Old Jul 2, 2004
Can I use the e-manage ignintion timing feature instead of an adjustable CAM gear to retard my timing?
Old Jul 2, 2004
I have my Profec e-01 set up to control most of the e-manage settings, and will take some pics of that when I get back in town. I havn't used it too much yet, as I am still waiting on my turbo system to arrive, but I tried the vtec engagament change point, and that was fun messing with.
Old Jul 2, 2004
opto_isolator's Avatar
No - emanage controls ignition timing, not cam timing.....
Old Jul 2, 2004
Cool, that clarifies the timing question thanks.
Doesn't anybody have any maps to post? Or are they all "secret?"
Old Jul 3, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
If i were you, I would go post on team-integra.net, everytime I go to a integra meet, eveyone is using a emanage.
Old Jul 3, 2004
Thanks, I will check them out.
Old Jul 5, 2004
OK, so I found some D16 on 10 Psi Boost Maps that might be of some help to me:
Looks like they didn't have the Greddy Pressure Sensor though.
Anyone think I can use these until I get the sucker tuned properly in a shop that has a civic e-manage guy, or will it really mess my engine up?
Name:	D16 10 Psi Dyno Tuned - Ignition Timing Adjustment Map.jpg
ID:	32247   Click image for larger version
Name:	D16 10 Psi Dyno Tuned - Airflow Adjustment Map.jpg
ID:	32248   Click image for larger version
Name:	D16 10 Psi Dyno Tuned - Additional Injection Map.jpg
ID:	32249   Click image for larger version
Name:	D16 10 Psi Dyno Tuned - Parameter Settings.jpg
ID:	32250   Click image for larger version
Name:	D16 10 Psi Dyno Tuned - VTEC Settings.jpg
Old Jul 5, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Now, I don't have an e-manage, nor have I worked on one, BUT I've done ECU map tuning on plenty of other vehicles using various programming similar to the e-manage... The ignition map you posted looks, well, odd. Adding 5 degrees before boost and then taking out 5-7 after boost??? Sounds like an arbitrary decision on numbers and does NOT look like thats a real tune on the dyno.... I remember seeing someone else's e-manage maps on here and they had it the right way: gradually taking out timing as boost rises...
I could be wrong, but it doesn't make much sense to me why it's setup that way....
Maybe try and get ahold of Boosted2k2 because I know his was running an e-manage and he had a healthy setup....
Old Jul 5, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
we def need to get the mapping right for our cars.
many of us r getting tryin to figure it out. lol
Old Jul 5, 2004
I just sent a PM to Boosted2k2, hopefully he can offer some help on this issue.
Old Jul 7, 2004
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
ive got a map with the sf kit at 10psi but i dont have access to it right now...
Old Jul 7, 2004
Can you please post it when you can? Along with any mods done to your car, like different injectors, headwork, anything....
Thanks
Old Aug 10, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
well its been 4 weeks, hav access to it yet?
Old Aug 17, 2004
RoBBUsaF's Avatar
lol... car is fvcked again. no map sorry.
Old Aug 17, 2004
nice ill b using this
Old Aug 18, 2004
What hapened?
Old Oct 30, 2004
Crackhead79's Avatar
suscrbing hope to use some of these maps soon as a reference....thanks guys
UltraHDGames
Jun 8, 2016 05:16 PM
Hutch1051
Sep 29, 2015 09:20 AM
2.0.0.2
Sep 14, 2015 06:38 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
