Vacuum line
Old Jun 15, 2004
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
Vacuum line
Two questions...
1. Where's the vacuum line off my throttle body? Which line is it? I can't seem to find which one it is.
2. How can you tap off the vacuum line... buy a splitter? I need to hook up the blow-off valve and wastegate to my vacuum line.
Old Jun 16, 2004
Havok2k1's Avatar
Wicked Pissah Admin
http://www.7thgencivic.com/forums/sh...65&postcount=3
Old Jun 16, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
ok when the instructions tell you to do this,
"The vaccume line for the boost guage and the FMU and the BOV comes from this line."
WHat fmu is he talking about (the fuel pressure regulator that he calls the fuel kit)?
Old Jun 16, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
u can pic up n e line coming off the intake manifold. just use a "t" connecter just make sure it seals. there's like 3-4 small lines in the back.
Old Jun 16, 2004
NoSpleeny's Avatar
I see that image but which line is the vacuum line? Can anybody give me a bigger more clear picture of the vacuum line?
Old Jun 16, 2004
Havok2k1's Avatar
Wicked Pissah Admin
The bottom one labelled "vacuum line"
I think Madwheel took a better pic a while ago.... Or maybe I'm just crazy....
Old Jun 16, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
if you attach a vaccum line to the waste gate, you should really try to make the line as small as possible. of course with our cars, this means tapping it into the pre-turbo intake.
Old Jun 16, 2004
NoSpleeny's Avatar
What happens if you don't hook up your blow off valve to the vacuum line? What if you don't hook up your wastegate to the vacuum line?
Old Jun 16, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I dont know about the bov, but the wg wont be regulated and it will boost at watever psi. There will be no pressure to hold it at a steady pressure point what ever that may be. I think that some bovs dont require a vac line. You MAY be able to slide with out connecting the vac line to the bov, but the wg needs to be connected or ELSE. Take it from me, i forgot to hook up the wg vac line and the boost went way up to 10, my car is tuned to run 5psi. Be careful.
Old Jun 16, 2004
NoSpleeny's Avatar
Ohh... What do I use to tap onto the vacuum line?
Old Jun 16, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
t fittings?
Old Jun 17, 2004
NoSpleeny's Avatar
Are there any X fittings? Since I need to plug 3 things into that vacuum line?
Old Jun 17, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
There are T fittings that have 3 nipples on them. Go to autozone.
Old Jun 17, 2004
Mex's Avatar
Mex
if you have a manual boost controller, will the wastegate still play a role in boost? I'm not really sure where the MBC hooks up to...
Old Jun 17, 2004
NoSpleeny's Avatar
That's what I want to know too. Where do you hook up the manual boost controller?
Old Jun 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh it does
the wastegate is the minimum boost you will hit
a MBC can only increase it. It can't make you run any lower than what the stock one is set at
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
powman02
Sep 15, 2015 07:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
JJ291
Sep 2, 2015 11:49 PM
