Tapping oil pan, help!
Old May 21, 2004
Samari's Avatar
Okay, since i have an EX and the pan is aluminum and its going to be hard to find someone to be able to weld it, i came to the decision that it would be easier to just tap the pan put the fitting in there without welding it.
I know SF came up with a way so can some please help me out. Thanks in advance.
Old May 21, 2004
Samari's Avatar
help please.
Old May 21, 2004
civic01vtec's Avatar
not quite sure what you are asking
SF's fitting is a triangular piece with a tube in the center. At each corner of the triangle is a bolt. You drill your hole for the tube, then drill the holes for the bolts and bolt it up.
Old May 21, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
SF has a fitting that bolts into the oil pan. You just drill the normal hole for the fitting then three bolt holes. It's hard to explain...the fitting comes pre-welded in the center of a triangle piece. You then use three nuts and bolts to attach it to the inside of the pan with the fitting sticking outside. I know that a while back when SF started offering this someone made drawing of it to better explain. Hope this helps a little
Old May 21, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i know nothing about this sf turbo kit, but from the way it sounds, you dont need to weld this piece in the oil pan, since you were debating about it in the other thread. just put some very oil resistant rtv around the fitting, and bolt it into the pan. but let it fully cure before you bolt the pan back on and put oil in
Old May 21, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
Sam, whatever you do, DO NOT us any type of oil RESISTANT RTV silicone...others may stand by it, but eventually you will be doing something else to fix it...i am a prime example of that....that is why my fitting is welded...if you do use the silicone, make sure that both contact areas are spotless....no oil, dirt, etc.....because if you dont, it will not last....i used the best silicone know to man, that several shops suggested...and it still didnt work....might as well do it the right way first
Old May 21, 2004
ctx66's Avatar
then you obviouly did something wrong. people use rtv in oil areas all the time, hell, on my old car the oil pans entire gasket was rtv, from the factory, and after i took it off to replace it. just because you used it wrong doesnt mean it sucks
Old May 21, 2004
Samari's Avatar
He got u wes, lol, you got OWNED!
Old May 21, 2004
i used Komatsu (heavy equipment maker) gasket maker and used copper washers for the nuts and double nutted it........mine will never leak
Old May 21, 2004
Samari's Avatar
so do i need to find a fitting with threads on both ends, and the find 2 copper washers, 2 bolts, drill the hole and put the fitting through, put the washer and bolt on each end and then put komatsu on both sides?
This appiles to CIVIC01VTEC, you seem to be knowledgable.
Old May 21, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You could tap the pan to accept the fitting directly. But if you get less than 3 threads, you are not going to get a good seal. Adding sealant is only a slow down, not a fix. The right, best, and most reliable way is to have a bung welded in by a competant welder. Any good welder can heliarc aluminum, when it is done properly, you will have a connection that will outlast everything else and never leak.
Old May 21, 2004
andyman97's Avatar
Turbo Guru
I concur 100%
Old May 21, 2004
well, i just got off the phone with you and you are gonna try the other pan, but i will explain what i did anyway
The SF fitting is a triangular piece of aluminum about 3/8th's thick with aluminum tube going through the center for the oil return hose which is welded on the outside of the tube to the triangular piece. At each corner of the triangular piece is a bolt to bolt it to the pan. SF gives you bolts and a lock nuts and on the head of the bolt they cut half of it off so when you tighten it down, the head will sit flush.......this is a horrible design
What i did was put the fitting in a vise and took a file and filed away some of the weld so a full bolt will sit flush, i then used a longer bolt than what they gave us and put the nuts on the outside of the pan with a copper washer on the bolts on the inside of the pan and put gasket maker on around the washer and slide it through. I put gasket maker on the triangular piece and bolt it down and double nutted every bolt.
That is the best way i could explain it w/o pics ..... hope you get the idea.
Old May 21, 2004
jwcardy's Avatar
there are several others on here that back me up on what i said...like i said, and another,(couple posts down) it is only a slow down......the right was is to weld it....
sam, i own you, what are you talkin about
Old May 21, 2004
Samari's Avatar
The LX oil pan seems to fit the ex or it looks like it will bolt up. both have 18 holes and 18 bolts/nuts. I will finalize this theory soon.
Old May 22, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
hey sam, good luck and I'll be there thursday and u'll be helping me the following weekend coming up
Old May 22, 2004
Samari's Avatar
LX/DX pan fits the EX
Old May 22, 2004
arghh
Welding a bung in the pan is so easy. A five dollar bung, twenty dollars for the welding job, unless you have friends. Nothing protrudes into the pan itself, so not obstruction problems, and it will never come loose, no bolts to fall off and find their way to something interesting.
Plus, with the pipe threads and sealant, it should never, ever leak. Why save money only to worry later. But it is only the engine oil.
Old May 22, 2004
Samari's Avatar
arghh
I agree with u man. i was exploring my options and luckily the lx pan that was tapped with the fitting welded on fit on my ex so its all good.
Old Jun 11, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
does anyone have pics of where they drilled the oil pan for the oil return line (on an EX preferably)? I am gonna order a new pan off majestic honda's site to get the install done faster. also, has anyone attached it other than welding? I'm wondering if JB weld would work for this application. I'm also going to attach some kind if rubber gasket to help seal it good.
Old Jun 11, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
http://www.artistontheloose.com/Pages/turbo.html
Old Jun 11, 2004
Mex's Avatar
Mex
good stuff marcus, thanks
Old Jun 12, 2004
no prob
Old Jun 12, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
The EX pan has an extra baffle in it though. Don't you need that if you're using an LX pan? Did you bolt that on your new pan?
mrwhos
Aug 11, 2015 02:03 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
Q-Bert
Jul 19, 2015 09:09 PM
