7th gen oil pan's
Old May 19, 2004
Samari's Avatar
7th gen oil pan's
I just got an sf kit and the guy that i bought it from sent me his oil pan with the bung welded to it. The thing is he has an lx and i have an ex. Is there really any major difference between the 2, and shoudl it bolt up to an ex?\
Thanks for the help in advance.
Old May 19, 2004
dj02's Avatar
-edit
my B! the pans are diffrent 2 total part#
lx oil pan #370648 fig-4
ex oil pan #370649 fig-5
Old May 19, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
it looks like a couple of bolts and holes r a lil different. but if its alluminum its an ex, if its steel its a lx or lower.
Old May 19, 2004
Samari's Avatar
I was talking to someone and they said that it might be differenet sizes. And if it was, maybe it was because of vtec so the ex might need a bigger pan? Not for sure, but if its not a problem then i hope the lx pan will bolt up.
Old May 19, 2004
nothing about v-tec is in the pan its all valve and cam(top of motor)
i would call and ask honda the part # of a ex and lx pan if there the same than thats your answer.
Old May 19, 2004
Green Civic's Avatar
I dont believe its different. I'd call honda to see if there is a difference. The lx and ex use the same amount of oil, so there would not need to be a bigger pan.
Old May 19, 2004
dj02's Avatar
^^ check my og post they are diffrent
Old May 19, 2004
You edited after my post.
hhhmmmm........ There are diferent part #'s. I guess they are different. Sam, I guess you have to get the fitting off the lx pan or get the fitting for your pan.
Old May 19, 2004
just tap your pan carefully and thread a fitting in there and jb weld it thats what i did and it works great just make sure you change your oil after you drill it.
Old May 19, 2004
Samari's Avatar
they are different part numbers, but they still could fit. Ill call honda to make sure though.
Old May 19, 2004
Samari's Avatar
Okay, I just called them and they dont know. Told me the same stuff yall are saying.
Do you think a muffler shop could weld it for me?
Old May 19, 2004
dj02's Avatar
they should be able to.
Old May 19, 2004
civic01vtec's Avatar
I take it that you have to send your oil pan to the seller?????? Well if so, your pan would be worthless to him. You are gonna have to drill and tap your stock pan. Call SF or PM Catalyst and see if they will sell you a oil pan fitting for you oil pan.
btw, i wonder why honda made 2 different oil pans
Old May 19, 2004
Samari's Avatar
no the other guy sent me his pan along with the turbo kit i bought. I can just go to a hardware store and match up a fitting or get the shop to cut the old fitting off the other pan and weld it to mine.
Old May 19, 2004
you cannot use the old fitting........you cannot weld aluminum to steel like that. You can go to a hardware store and make you own, but i would just buy one from SF.
Old May 19, 2004
a muffler sho wont be able to weld it. you said u have a ex right?? its an alluminum pan. 99% of shops wont have that kind of welder.
Old May 19, 2004
Samari's Avatar
lol, things are going great!
Old May 19, 2004
dragoon's Avatar
black oil pans are dx/lx and silver ones are EX
Old May 20, 2004
andyman97's Avatar
Turbo Guru
Holy misinformation, batman!
First off, oil does have something to do with your head as well as the block. You don't think that oil lubricates the head as well?
Second, ex and lx,dx do not use the same amount of oil. EX uses 3.7 qts, LX, DX both use 3.4 qts.
Third, a muffler shop should be capable of tig welding an aluminum fitting into an aluminum oil pan (assuming that the oil pan is, in fact, aluminum-I am not sure either way.) You just need to find an aluminum male fitting that is the same size as the return flange on the turbo.
Sam-The part numbers are different and by the comparison of the two pans in the drawing, they seem to be different pans. Don't use the lx pan you got. Just pull yours and get a fitting on it or order a new one. We're still on for Sunday so get that **** knocked out. It's not as big of a deal as you think so don't sweat it too much bro. Call if you need anything.
Old May 20, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I couldnt have put it any better lol
Old May 20, 2004
Samari's Avatar
lol, good **** andy.
Old May 20, 2004
Samari's Avatar
ps - where can i get an aluminum fitting?
Old May 20, 2004
Misinformation??????? hmmmm........seems like i said the same thing on page 1.........
Old May 20, 2004
you can get one from SF ........but you will have to sligthly modify it to make it leakproof. No big deal.
Old May 20, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Have you tried to measure the holes? I might be the same. I would not give up so easy.
Old May 20, 2004
Samari's Avatar
i havent tried fitting the lx pan yet. I will sometime but i have my last final so im not doing anything car wise just yet.
Old May 20, 2004
ohmysac's Avatar
ohmysac is an unknown quantity at this point
just to let you guys know the difference in the lx and ex pans besides holes is that the lx pan is steel and the ex pan is aluminum...
Old May 20, 2004
Samari's Avatar
i think we already established that!
Old May 20, 2004
andyman97's Avatar
Turbo Guru
I didn't say it came from you. Just what was contrary to what I posted. If you agreed with what I said, it wouldn't make sense for me to say THAT was misinformation.
SimpleUser
Apr 24, 2021 02:54 AM
brags
46
Jan 7, 2016 09:39 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
