turbo ex or turbo si?
Old May 13, 2004
civic30's Avatar
civic30 is an unknown quantity at this point
which would u rather have and why? because around where i live, used ex's and si's go for about the same price
Old May 13, 2004
Bowlcut7's Avatar
Bowlcut7 is an unknown quantity at this point
what year SI, either way with the older si, 2000, the B16 will definitely get more power, same with the k20 in the 2002. The D17 is prolly the worst out of all of these.
Old May 13, 2004
dragoon's Avatar
turbo SI, if it's a 99-00.
the 03 SI has potential also, but it's ugly.
that's my story and i'm sticking to it.
Old May 13, 2004
MadWheel's Avatar
Premium Boosted Member
if you're all about performance, Si no matter what year...
In taste though, I turbo'd my EX because to me it looks nicer when you tweak it lol
Old May 14, 2004
Spider883's Avatar
9K Redline Owns U
yes the si looks like a mini van.. but who cares? not i.... and im running 8lbs of boost on the sc so its cool
Old May 14, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
hey how much power are you gettin mr. ihaveablowersoimfasterthaneveryone? hehe
Old May 14, 2004
Spider883's Avatar
9K Redline Owns U
no idea whatsoever.. i raced a celica gts that has i/h/e and runs 14.2's at the track from 15mph-100 and had 5 car lengths on him.. so its decent
Old May 14, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
^^^^^ nice
Old May 14, 2004
civic30's Avatar
hmmm...... how much psi u runnin? cuz wouldnt that put u in the mid13 range
Old May 14, 2004
Spider883's Avatar
9K Redline Owns U
^^^ i have no idea... i need to go to the track once i get a new clutch
Old May 18, 2004
esmith13's Avatar
esmith13 is an unknown quantity at this point
turbo EP3 (02-04 Si)
I have one. Stock BLOCK (not pistons) was built to handle 28psi SAFELY. Ask any honda tech or grab a service manual.
I'm runnin 10.5psi. I put 24,000mi on my turbo kit in the 9mos I had it - not a single problem EVER.
267WHP/215TQ
ran a 13.511 @ 103.76 @ 8psi (had a boost leak - silicone cuff was loose)
Goin to the track this friday at 10.5psi to see what she's got.
This is all with the cybernation kit on a stock engine, stock clutch and no lsd
Eric
Old May 18, 2004
Bowlcut7's Avatar
267WHP/215TQ
Eric
Thats exactly what im talking about. Those numbers right there are enough. Try and get those numbers out of a D17, i have seen them, but thats pushin it. Thats prolly what, cybernation stage 1. Stage 2 would put you well over 300 whp. Theres the potential of the K20 if you really want it.
Old May 18, 2004
esmith13's Avatar
yup - stage I
I could TECHNICALLY run 12psi safely, but i would need a 15lb spring in the wastegate (instead of the 10lb spring) and would then NEED a boost controller to safely prevent spiking above 12psi
So their's still room left.
Oh, and cybernation's new Guardian computer should net me more ponies without changing anything but the computer when it's released and i upgrade.
Eric
Old May 18, 2004
Havok2k1's Avatar
Wicked Pissah Admin
No need to post your 1/4 miles times and hp in three different threads man.... Put it in your sig if you want to....
Old May 18, 2004
esmith13's Avatar
As u can see by my post count - hevent really settled in yet...
Sorry bout that - not tryin to spam...
Eric
Old May 19, 2004
allmotor's Avatar
nor cal 7thgens
i have seen supercharged si's in sac and on 8 psi none have runned 13's
Old May 19, 2004
esmith13's Avatar
The biggest downfall of a SC is you can't Intercool them. The greddy kit for the Si has an OPTIONAL IC Kit. The difference in WHP is 40-60 depending on other mods (like exhaust).
That's why in most cases a SC won't keep up psi for psi with the average turbo setup.
Eric
Old May 19, 2004
civicskater's Avatar
Chicks dig my scent
get a 99-00 Si..tuned right ive seen them pushing near 20psi on a stock block easy. They put down big numbers as well. Either way you're going to get power from boosting ANY motor, its just that the B16 and K20 will give bigger power with the same boost on a D17, plus they're stronger motors stock
Old May 19, 2004
gotti's Avatar
Hop off him man, he was actually adding to the thread.
Those are some good numbers. Looks the k20 has a hell of a lot of potential.
Old May 19, 2004
civic01vtec's Avatar
agreed
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
