Head specs - with torque numbers and sequence
Old Apr 16, 2004
MadWheel's Avatar
Premium Boosted Member
Here you guys go:
When removing, follow the sequence and loosen bolts 1/3 at a time.
When putting on... Follow the second sequence, and torque to 14 lb-ft. Then with the same sequence, retorque to 36ft-lbs, and then the seqence again to 49ft-lbs (I'm setting that to 51.)
Doing that seqence will prevent head warping. Hopfully this helps you guys out.
Old Apr 16, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Re: Head specs - with torque numbers and sequence
Originally posted by MadWheel
Here you guys go:
OOPS...
I did it wrong. But at least it worked. I torqued mine to 51 also.
Old Apr 16, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Excellent Info, Thanks madwheel!
Old Apr 16, 2004
MadWheel's Avatar
No prob man. Yeah that's why I waited on my HG lol...
Wild Cranker
427
Jan 28, 2016 06:49 PM
Jun 2, 2015 11:54 AM
juror
May 26, 2015 06:35 PM
Grey
16
Jan 27, 2002 11:34 PM
ayzan
Dec 28, 2001 10:47 PM
