Tps?
Old Mar 29, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
Tps?
Where is the TPS used to activate WOT on the zex kit
Old Mar 29, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
You can use the ECU or the sensor wire.
The ECU wire is connector A, terminal 15. A red/black wire.
To use the sensor though, you'd have to figure out which wire changes voltage with throttle position. My guess is the middle wire based on the electrical diagram from Honda, but I can't say that the diagram is accurate in respect to the actual wire order.
Old Mar 29, 2004
Which would be easier? And how would i wire it into the ECU?
Old Mar 30, 2004
I need the output voltage lead from the throttle position sensor?
Old Mar 30, 2004
Boosted2k2's Avatar
~0.5V closed
~4.8V open
Thats the wire your looking for.
Old Mar 30, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
What's easier depends on you. The TPS is pretty damned visible once you pop the hood. The ECU u'll have to remove or drop down the glove box to access. Either way you do it....it's fairly simple.
Tyler93
Mar 20, 2016 09:03 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
thaler4cuse
Sep 7, 2015 08:25 PM
Martinez8o5
Jul 31, 2015 10:58 PM
Jul 12, 2015 11:54 AM
