Simple N2O question
Old Mar 28, 2004
CRNewson's Avatar
CRNewson is an unknown quantity at this point
Simple N2O question
I read on the FAQs that I need to have non platinum spark plugs if I am going to be installing a spray kit. They also mention "colder" spark plugs. I don't really know what that means. If someone could explain to me a little of the why behind this, I would be most appreciative.
Old Mar 28, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
The colder spark plugs will not have as hot of spark, further preventing detonation due to, too hot of combustion
Old Mar 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
Heat range has nothing to do with the spark its self.
The primary means of adjusting heat range are by varying the length of the core nose and the alloy material used in the electrodes. Hot plugs have a relatively long insulator nose with a long heat transfer path. Cold plugs have a much shorter insulator nose and thus, transfer heat more rapidly (see illustration; hot to cold - left to right). The heat range of a plug does not affect the power output of an engine. Rather, it allows the plug to function as designed for the duration of the racing event. In other words, once the correct heat range is found that prevents fouling and does not contribute to the pre-ignition or detonation, a change to a hotter or colder plug will not have a positive effect on engine performance.
http://www.edelbrock.com/automotive/sparkplugs.html
Tedverseti
Apr 23, 2020 01:45 PM
baconomics
Aug 26, 2015 07:47 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
BootyDo
Jul 7, 2015 06:06 AM
