Some boost and swap Questions
Actually MSD has a independent ignition system that works with any OBD II 4 cylnder. It totally replaces the curent ignition system, down to the wires. It's pricy though, around 1,200 bucks after you get the coil, cumpter and all the sensors. It's a pain to install too since you have to mount the sensors, I think they're a knock sensor and crank sensor, not sure. But if the Emanange system works, use that then.
But anyway, I was just using it as an example, I haven't messed with my ignition and have no plans to, so I'm not up to date on that stuff... Sorry boosted, I'm going for the K20 swap in the fall.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
